Does the position of the Speedometer/Tachometer bother you
#34
#35
#36
I would rather the speedo and tach were reversed. I'm nowhere near gansta, but I do like to drive with my left hand at 12 and my right elbow on the rest. That means the speed is sometimes covered and I have to peek over my forearm to see it. If they were switched, the normal speed range would be near the middle of the dash, so it would be easy to see.
#37
That is either a serious gangsta lean or bad wheel alignment. If I gripped the wheel that way, I wouldn't worry. The orange glow from the dash will shine over your arm when you are speeding over 75 mph. No need to look at the speed at that point.
#38
I have the steering wheel almost all the way down, so its not like my arm is above my head or anything. It is just where I like it(like sticking arm out straight and driving). But I have the seat leaned back a lot which is why the steering wheel is almost on the lowest setting it can go(fully extended outwards too).
with the way you are sitting and holding the whell, you will never have the best control of the car and it's performance that you can
Ace00
05-03-09 01:51 PM
