Does the position of the Speedometer/Tachometer bother you
Especially if you drive with one hand near the top of the steering wheel, your arm tends to block your speedometer.
I'm guessing Lexus didn't want to switch it for the states.
I don't recall any other car, even Lexus' for that matter that have the speedometer to the left and the tach to the right.
I usually drive with my hand on the bottom of the steering wheel, so it doesn't bother me, but a few of my friends always gripe about it when they drive it and when I do drive like that I tend to notice I have to lift my left arm up just to look at my speed, and with only the 20,40,60 numbers it's easy to be going 15 over and not even know it.
Maybe in a manual I can see where you would be coming from but in an automatic? The GS has the speedometer in the middle and the tach to the right so you can see both. The G35 has the speedometer on the right. The IS has all the gauge icons in the middle so the spacing between the two might bother people.
Looks like no one knows where I am coming from or cares, oh well
I have the steering wheel almost all the way down, so its not like my arm is above my head or anything. It is just where I like it(like sticking arm out straight and driving). But I have the seat leaned back a lot which is why the steering wheel is almost on the lowest setting it can go(fully extended outwards too).
If I recall correctly, the best seating angle for driving is 110 degrees, and if you're to use one hand to steer, it should be at the 10 o'clock position.
I sometimes drive one handed with my other hand on the shift **** as well, and I can see both the speedometer and tachometer perfectly.
It's all about the seating position, I think.
You have to sit closer to the steering wheel, so that you feel engaged in your driving.
Just my thoughts.
I drive at 10 - 2 and I still find that there is a flow in the gauges cluster design. The problem is that as you adjust the steering wheel, the top end of the steering column could cover the top/sides of the gauges. I wish they did it like in the G35 telescoping thing where the steering column and the gauges are synchronized so that each tilt of the wheel has a corresponding gauges movement that maximizes the view and readability of the gauges.
Well with me i usually know how fast im driving but i think they should of put another option where you can change the center screen where u diplay the tank avg. etc to ur speed. I think that wouldve been more convienient for people who drive with thier hands at 12'o clock
Actually I was/am considering installing a Head-Up Display (HUD) but I can't seem to find one that I like.
