Getting my TPMS programmed
I just bought a set of used TPMS sensors off of 2005 SC430, which I am planning to use them on my second set of wheels.
I was wondering if anyone know if there is a fixed price what the dealer charges to program them or does it vary from dealer to dealer? If anyone can tell me how much I should expect to pay, that would help.
I did search, and I only could find the charge including mounting and balancing. Thank you.
I may be wrong on this but I thought you had to have the dealer do it. You have to program the serial numbers of the TPMS to the car ECU. I'm not aware of you being able to do this yourself... the only thing you can do yourself is set the desired pressure and which TPMS sensors to use.
I know in the information screen you can select 1 or 2 for TPMS but I see nothing about programing it.
Super Moderator
I believe teejnut is right, the dealer has to enter the serial numbers with the scan tool. Obviously that means you want to record the serial numbers before you mount the tires on the rims.
I have a second set of tires with TPMS. Here is what I had to do:
Write down the serial number before mounting the PACIFIC brand sensors. In my car here is the setup
Tire Pressure Sensor numbers
(2nd set NEW)
Right Front Sensor
88A00F7
Left Front Sensor
899A0F7
Right Rear Sensor
B7EF0F7
Left Rear Sensor
8AFD0F7
(1st Set Main)
ID1 Code
3F231E3
ID2 Code
05C31E3
ID3 Code
FF241E2
ID4 Code
06121E3
I gave this list to Newport Lexus and told them to program it like this. I got the original main set numbers from the ECU scan from another dealer. Trust me, many dealers are confused that the car has a 2nd set option, they kept on insisting to wipe out the main set. Anyways, Newport Lexus did the job for free.
(I did not purchase the car from them)
(2nd set NEW)
Right Front Sensor
88A00F7
Left Front Sensor
899A0F7
Right Rear Sensor
B7EF0F7
Left Rear Sensor
8AFD0F7
(1st Set Main)
ID1 Code
3F231E3
ID2 Code
05C31E3
ID3 Code
FF241E2
ID4 Code
06121E3
I just purchased new wheels and TPMS sensors, the dealer set them up as the secondary set. I had the sensors and wheels installed at a local shop, wrote down the numbers and the matching tire and the Lexus dealer entered them into the on board computer.
Do you know how much you paid for having the sensors programmed?
I went to the dealer yesterday and turned off the DRL and programmed 2nd set of TPMS. You will have to use their computer and connect to your OBD system. The TPMS registration will give you 5 mins to input all 4 sensor code into the database. I got a set of TPMS from a Toyota which made by Pacific and it works. On the computer screen, you can see the sensor ID, temperature, pressure off each sensor, including the spare tire, and you can also program a certain pressure point to set off the Low Tires Pressure warning. So you can just grab a set of TPMS off of a Toyota as well to save some $.
I went to the dealer yesterday and turned off the DRL and programmed 2nd set of TPMS. You will have to use their computer and connect to your OBD system. The TPMS registration will give you 5 mins to input all 4 sensor code into the database. I got a set of TPMS from a Toyota which made by Pacific and it works. On the computer screen, you can see the sensor ID, temperature, pressure off each sensor, including the spare tire, and you can also program a certain pressure point to set off the Low Tires Pressure warning. So you can just grab a set of TPMS off of a Toyota as well to save some $. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
This is very helpful information. Now, we can some money by using Toyota TPMS sensors instead of high priced Lexus ones. Thank you!
To make things easier for you, I would recommend having Lexus or Toyota intially mount the sensors to the wheels and program them. When times comes to replace your tires in the future you can take them anywhere you choose since they are already registered and installed (and known to work).
