Unlock all doors
#31
Super Moderator
I hate to add on to this old thread but didn't want to start a new one. When I drive, I'm usually the only one in the car. All my doors unlock fine as per this thread, however, when I get to work, I open my door and all the other doors are still locked from going over 13 MPH during my commute. Is there anyway to unlock all the doors and trunk when you shift into park?
step 1: Close all the doors and switch the engine switch to IG-ON mode. (Perform the step 2 within 10 seconds.)
step 2: Make sure shift lever is in Park, and hold the unlock button on the driver door for EXACTLY 5 seconds.
When the setting or canceling operation is complete, all doors are locked
and then unlocked.
#33
Any way to make all the doors unlock with just ONE press of the keyfob unlock button? I'm usually getting in the rear door first to put my stuff away, and THEN I go to the front to get in. No time for finger banging the door handles, I want to unlock my doors before I'm even up to the car. Can our 2011's do that?
#34
Yes. You can program your fob to do that... Search is your friend. :~)
hold the LOCK / UNLOCK buttons down together (on the SmartKey until the Car beeps... now it will unlock all doors when you touch.
hold the LOCK / UNLOCK buttons down together (on the SmartKey until the Car beeps... now it will go back to only unlocking the drivers door
#36
I did, and it didn't work, which is why I asked the question. That procedure is just to have the rears open along with the fronts when your hand touches the door handle. I want a single button press on the key fob to do it.
#37
Posted here in my build thread #12 and other tips.... An ISC owner said it does not work. It does work on my sedan.
https://www.clublexus.com/forums/bui...nance-diy.html
>> Smart Key Unlock all doors one press:
Default mode is one click opens drivers door (or door touch), two clicks unlocks all doors.
On key fob and when in range of car push and hold both lock and unlock simultaneously for about 5 seconds. Car Chirps repeatedly.
If drivers door is opened, all doors open. If Fob is pushed once, all doors unlock. Car chirps 4X.
To return to single door/single button press, push both buttons for 5 sec.
#38
Nonono... I don't want my fob to do it. I want them to unlock when I touch the door handle. Currently, when you use the keyless access (touch the door handle with the key in your pocket), it unlocks only the driver's door. I want the keyless access to unlock all doors. I have already programmed my fob to unlock all doors.
I need help with this too
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
