View Poll Results: What do you use?
Have XM Radio, use it and like it.
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
16.67%
Had XM Radio, didnt like it shut it off.
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
8.33%
Have HD Radio, use it and like it.
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
8.33%
Have HD Radio, dont like it.
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
0%
Dont use/have either XM or HD Radio.
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
66.67%
Voters: 12. You may not vote on this poll
FYI DICE HD Radio Unit for Lexus avail @ Costco.com w/ $40 MIR
The unit works but it's not perfect yet.
I have one in my 2007 GS350, and not all the functions and displays advertised work... However, the sound from the HD Radio is amazing.
It was explained to me that the unit worked well with the 2006 GS, but Lexus changed something on the 2007 GS. So, I'm not sure if you IS owner's will have the same problem.
The company does stand behind their product, but I feel the product is still under development.
Mind sharing some pic's of your setup, i know it will be different in this IS but i wouldn't seeing some of the setup
The screen looks exactly like the CD changer screen.
The Unit is temporarly tucked under the passenger floor mat...it won't be mounted until I have time to visit dice again and have more functions operate correctly. The unit is sort of big and will not tuck away easily. I'll post up some pics this weekend, if anyone wants.
Did you know you can purchase the unit straight from dice for less than the Costco price, and still send in for a rebate? Check out their store site... I know, they don't have the Costco return policy... but I thought they (Costco) changed that for electronic goods
Yes, you do... but since they're sort of local to me, I have arranged to stop by their office/warehouse/tech center in the Lakewood, Ca. area (not sure why their website states that they are located in Nevada) in the past.
so how large is the antenna? and can it be hidden in the car? can it be stuffed in to one of the pillars or can you mount it in a way on the back window from the inside that will hide it? i just ask as a few years back i had XM installed on a BMW and they where able to put the antenna in the car and you couldnt see it and i had no issues with it.
Thanks for all the info this sounds like its worth checking into.
It doesn't bother me as much as when I first installed it. If you know it's there you can see it from outside. I haven't found any better solutions.
FYI...
Keep in mind that, You need to be in an area that transmits HD to get HD Radio in your car... most metropolitan areas do, but once you travel outside the transmittal area you revert back to regular FM/AM (through the HD Unit) if you're listening to HD FM/AM. For the "channels in-between" you just hear silence if you've traveled beyond or if you're in a dead spot (like sirus radio).
The antenna is 1.5"X1.5" square plastic (Picture the interior portion of an old car celluar antenna) stuck to the top passenger corner of the interior windshield with a piece of tape with a very thin wire (hairlike) in middle of the tape, running down about 1" parallel to the side edge of the windshield. << That is Dice's recommended installation location. I opted to instead, run the tape 1" parallel to the top edge of the windshield (which doesn't interfer with the passenger's line of sight out of the windshield).
Thanks very much for all your input too! Its been very helpful!
Oh that would never do... Id have to find a way to maybe run the wire all the way to the back and set it back there with some velcro near the rear speakers or something. I could never live with anything taped to my windsheild!!!
I called dice yesterday and asked the question about display on our NAV.. they said only if the current CD player has text capability... meaning you pop in a cd and the song artist etc... shows up on screen. Mine does not unless I'm missing something??? Maybe I'm to old & my CD's do not have text?
If it does, I think this would be great! Anybody know if the non ML stereo's display CD text?
<<<Me thinking outloud >>> Maybe I'm too quick to say the sharkfin would not work...hmmmm
