Bluetooth
I accessed this hidden menu and increased the bluetooth volume all the way to 5 and found it to be too loud. I increased both speaking and hearing volumes to 5 and that was a bad idea. I believe the factory setting is at 3 so I changed it back to 3.
This hidden menu will also let you check other things such as your audio and NAV and if there were any errors, it would tell you. Only thing is, unless you know what the error codes mean, it's pointless to access this menu. You can also reset certain errors but don't do it unless you know EXACTLY what you're doing. I've been told that we're not supposed to access this screen at all so don't go into your dealer telling your service guy that you were fooling around with this screen!
Hold down the INFO Button if you have NAV... and turn your headlight signal from the off position to the the middle position (the position before you turn your headlights on) back to off and keep doing that until your nav screen shows an alternate menu with one of the options being bluetooth...
You can look through that and you can adjust the sensitivity.
i have to try this tonight. my bluetooth something won't connect.
Yea I played around with it a little last night. Nothing specialy. Just a bunch of diags we can do little with. Uped the bluetooth send and receive volume to 3 and left it at that. Havent tried it yet, so we'll see.
DrummerK
01-14-07 12:07 PM
