Stalling in the morning - TWICE!
Has anyone's IS stall right after ignition? It happened to me TWICE, different mornings, about 63 degrees F.
It was weird cuz, I was ready to go so i hit the push button, heard the ignition, then the gauges do their normal spin, then i was like im ready to go, then put the car in reverse, and it didn't move, then i saw the engine was stalled.
This morning it did the same thing.
hmm..
hmm..
Whoa.... Better take that in buddy. Thats not good. I leave my house at 6am everyday and its lately been around 50 degrees Fwith no problems... Imsure a lot of other on here start theirs every morning a lot colder... You should let the dealer know.
hmm..
hmm..
Was your start button light green when you hit it? I usually wait a couple of seconds after applying the brake before I hit the start button.
I wouldn't panic. Are you sure the engine actually started before you try to shift it out of park? If you are sure of that I'd dump a bottle of Heet, or other drying agent, in your tank to absorb any moisture. Fill up with a fresh batch of gas and see if that solves the problem.
Shell V-Power
and yes i heard the car do its ignition "cht cht cht" sound from the starter motor, then rpm = 0.
just filled her up from Empty -> Full at a chevron, will see if problem still persists.
This happen to me before...
Well similar if it may be the case...
When i started the car, I was too fast to switch it into reverse and the car stalled.
But after I waited a second or so to switch it into reverse, the car had no problems.
Try slowing down for 1-2 seconds.. and see if the problem persist.
i dont think it's normal. the car is designed to start and go right? i start mine on and BAMN like that in reverse and go.... i mean if otherwise the manual or lexus would say so.
