Mobil 1
If you are using Mobil 1 fully Synthetic oil, one year or 15,000 miles is more than OK. Changing it more often is like burning money, and contributing to the oil shortage....
Well, yes....
Mineral oils are based on oil that comes from the ground, which has been refined. Synthetic oils are concocted by chemists wearing white lab coats in oil company laboratories, but they take mineral oil based products to manufacture. The only other type is semi-synthetic, sometimes called premium, which is a blend of the two, and is very popular.
Despite their name, most synthetic derived motor oils (Mobil 1) are actually derived from mineral oils - coming from the purest part of the mineral oil refraction process, the gas. PAO oils will mix with normal mineral oils which means you can add synthetic to your mineral, or mineral to your synthetic without your engine seizing up.
Time between changes, the optimum time for changing oil, is related to a number of factors, of which distance travelled is one of the least important in most cases. Here are most, in an approximate order of importance:
- Number of cold starts
- Ambient temperature
- Effectiveness of crank case scavenging
- State of wear of the engine (piston blow-by multiplies the problem)
- Injector effectiveness during warm-up
- Distance travelled (just to get that one out of the way)
Unless you enjoy contributing to the people trying to kill us, and you don't mind paying exhorbitant prices for a product we can't (for a number of political reasons) produce enough of, and you don't mind having supplies manipulated from OPEC to price gouge......it's a shortage.
Unless you enjoy contributing to the people trying to kill us, and you don't mind paying exhorbitant prices for a product we can't (for a number of political reasons) produce enough of, and you don't mind having supplies manipulated from OPEC to price gouge......it's a shortage. ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
15,000 mi. oil change intervals? I don't care what you pour in it--that definitely isn't healthy!
I use Mobil 1 5W-30 exclusively for my daily driver, and although my engine is completely different from yours (OMG rusty American pushrods vs. JDM DOHC sweetness!), I still drive it daily and enjoy extracting every bit of performance out of it.
According to the onboard oil life monitor, I can usually drive up to 7,600 mis. between drain cycles. The oil analysis speaks for itself: Additional mileage will further deplete the amount of protective additives in the oil, subjecting the engine to higher levels of friction and heat.
http://www.doubledeez.net/CTS-V/Blackstone-2-22-07.jpg
When is the last time anyone heard of an engine blowing up because Mobil 1 oil was changed at 10 or 15,000 miles (or one year), rather than at 3 or 5,000. The correct answer is never.
I believe your onboard oil life monitor is driven by either time or miles. It sure isn't determining the condition of the oil, which is a bit of a "black art" (pun intended) anyway. Well done using a lab. I assume you plan to get well over 100,000 out of your motor.
What works best for your car depends on these factors among others, including driving habits and environment. I suppose the only way to properly judge this is to have it analyzed and adjust your change intervals accordingly.
