Volk Progressive ME - Question
![](http://www.jdmracingsports.com/Bilder/Felger/Volk/prog-me-2.jpg)
Hey guys I'm going back and forth on some wheels for my car and I am leaning towards these.
I found some in these sizes: 19x8.5 +29 & 19x10.5 +43, will this fit on an IS350?
I'm not too sure about the offsets.
You may want to talk to glilly... he's got them on his... check it out
https://www.clublexus.com/forums/sho...d.php?t=229495
19x8.5 +29 & 19x10.5 +43 will rub assuming you use 235/35R19 and 275/30R19 tires (common setup here on CL)
19x8.5 +38 & 19x10.5 +55 with 235/35R19 and up to 285/30R19 will fit without problem even lowered 1" on Eibachs all-around. A member here has done it but with a different wheel albeit with the same specs
Well I called around and was told for an aggressive setup:
19x8.5 +35 F and 19x9.5 +36 rear.
The only sizes in stock are 19x8.5F +29 and 19x10.5 +43. I was told this would fit but, the rear fenders would have to be rolled.
Any of this make sense?
how much are they asking for the set? i think the 10.5 in the rear is over kill but i love it. you may over tire the car with that wide of a tire. i would go with a 10" in the rear.
if you could PM me the info what you find out that would be great.
Thanks! & Good Luck!
FWIW, I would order the one's you're comfortable with. Sure it takes a while but wheels aren't something I would compromise on for the sake of convenience/expediency.
