Tire pressure and AWD
The door jamb sticker on the 250 AWD with Dunlop SP 5000M tires says to run 35psi front and 37psi rear. I know that it's important to keep the same tires and match tire wear on front and rear with AWD.
Why does Lexus recommend different psi for front and rear on AWD? I have been running the same pressure on both and a little higher than recommended. Will this cause any damage to the AWD system over time?
