Installing aftermarket sound system. need some info
i have 2 800 watt 12" rockford fosgate woofers and a 1500 watt 4 channel amp. i wanna run it to the stock head unit, do you guys have any advice before i go through with it. is the stock unit going to be fine running the subs? also, what can i do to ensure the system thumps and you hear me rollin up.
You also might want to reinforce with bolts/glue/welding, the rear view mirror. I'm sure with that wattage and our weakly secured rear view mirror, it will fly off on the first song.
I have the ML Nav system, and wanted more bass, so I bought an 800 watt Kenwood and 12 inch Alpine Type R in a Q Logic bandpass setup, and had Bestbuy install it. They added a line converter to it and it slams. I am not into shaking the neighbor's windows, but good quality sound, and this is perfect for it. And yes... I can shake the windows if I want to. Add sound deadening stuff though, b/c it WILL rattle everything including the plate and gas tank.
Correct me if I'm wrong but when you use the sound deadening isnt going to make the bass less noticeable form the outside, the point of deadening is to keep all the sound in, so it will be WAY louder inside the car but outside a lot quieter. My friend deadened all his doors and roof with it and when he's got the music up loud you hear barely anything outside the car, but inside its dam loud. If you want everyone to be able to hear it, dont put deadening in the trunk, but for the license plate, use some 3m tape on the bottom of it and it will not move .
1 Post
someone please tell me where to get the audio signals from? Some say to get it from the sub and some say the amp is clipping the sub when the volume is turned up high. I have a 12w6v2 and 500/1 ready to install but I want to know where to get the audio signal from. Does anyone have the schematic for the ML amp?
sorry to hijack your thread ROn
I am about to do something similar to you. The HU is fine, just turn ASL off. The non-ML amp has 2 channels. The ML amp has 1 channel so it is perfect. You should take out the stock sub and dampen at least some of the trunk and licence plate area. If you want to hear it knock outside, I'd just roll around with the windows down. I personally do not care for systems where the base causes the trunk to sound like ***** from all the vibration/air, I want something clean. I believe if you have an aftermarket amp you can still plug into the ML amp for some added power, not sure?Get a base **** too.
1 Post
