New Rotors with IS250 Brake Pad TSIB?
I was just wondering if anyone has receiving new or resurfaced rotors along with their new brake pads. I noticed there is a slight lip that has formed on my front rotors but not the rears. Is this normal or something due to the kind on pads already installed? Thanks for the input
Im getting the new pads tommorow i just didnt want screwed if they try to pull some BS and give me the run around about the service there are actually suppost to perform
I received new rotors with the brake pad TSB.... check out the HUGE thread in the brakes and suspension forum: https://www.clublexus.com/forums/sho...d.php?t=277068
Depending on worn condition and thickness of your rotors... some rotors can't be serviced. It is not cheap for O/E parts, and I'v seen some slotted-drilled aftermarket parts on fleabay.
BTW, it is the best timing to try some performance pads... like pads by Endless.
Pick my baby up this morning....No squeaky brakes thank god!!! They arent responsive as i expected but ill sacrifice that over the bloody noise. Next time i need new pads im gonna put on some aftermarket rotors and performance pads and see how they work out.
I got the TSB done. Does help with dust and as expected, the brakes don't stop as well. They were free, so I'm not complaining as I needed new pads. I too will go aftermarket performance the next time and back to the dust...
Not sure if my rotors were new or not. I think they just turned them. got the tsb done at 30k miles, so I'll be due for pads and rotors at 60k.
hlthlnk
09-07-10 07:41 AM
