Strange (bad) odor from the AC?
This is probably gonna sound weird, but I've noticed that on warm days, when my AC first turns on, the air it blows has a very distinct... BO smell. It goes away after it's been blowing for about a minute, but then it comes back every time I start the car.
And before anyone gets smart, no, it's not me
... I can very clearly tell it's coming from the AC vents, and there is no smell before starting the AC. There was no smell in the winter with the heater, and no smell with just the fan on (I think).
Has anyone else seen a problem like this? Any idea what might be causing it? Did something die back there?
![No No No](https://www.clublexus.com/forums/images/smilies/nono.gif)
This has worked for me in the past:
Turn AC on.
Change temperature to maximum heat.
Turn fan on high.
Run it for about 5-10 minutes. If it doesn't work do a search and there are several other methods for removing the smell.
Turn AC on.
Turn fan on high.
That new car smell after sitting in the sun gets pretty ripe all by itself in my opinion.
Old Oiler
I had my 07 RX350 in the burbs of Dallas for 6 months and also developed a bad/moldy smell from the AC. To cure it, I did the following:
1. With old filter still in, spray Lysol on the filter and into the AC intake with the fan on med / high.
2. Then remove the old filter for a new one.
Odor was gone. To keep the odor from coming back, every now and then I turned the AC to outside air flow as opposed to cabin recirculate. The fress air helped keep the odor away.
Although I'm back in Florida now (thankfully), I still allow outside air to flow every now and then.
I should mention that the air filter is pricey, I think about $60 or so. The same filter is used in one of our other Toyota products (06 Tacoma PreRunner) and could be purchased for $39 from Toyota. I'm not sure if the IS uses that same filter, but it may be worth it to find out.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
i find that when i use my AC, i turn off AC about 30 seconds to a minute before i get to my destination while keeping the fan on. shut off the engine and the next time i use the AC, i don't experience the bad odor from condensation.
i don't have to resort to using a spray or turning up the heat either.
