Would these rim size fit on my IS?
I am looking at some rims that are 18x8.5/front and 18x9.5/rear both having +38 offset. I am planing to run my stock tires (225/40/18, 255/40/18). Would this work on my IS350 without any issues? Thank in advance!
The wheels would fit, the fronts would be extremely flush, the rear slightly less, but still pretty flush. Of course you need to make sure the wheels will fit over the front brake calipers on your 350. As for using the stock tires, I think you might be stretching them out a little too much. I know the rears will fit on a 9" wheel and look nice but going wider may be a problem.
EyeKutr
10-09-07 06:09 AM
