help need info
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
hello everyone, when i brought my IS 350 it didn't come with HID
, but i just talk to this performance shop and they told me that if i could find OEM HID headlight they'll installed it for me for cheap cause my friend hooked me up. i was wondering if anyone here know where i could find a OEM HID headlight? and has anyone here convert their IS non HID headlight to an HID headlight, is you have please share how you did it, how much, and is it as good as when they comes pre-installed??? thanks in advance
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
why don't you just get the HID conversion kit from XenonDepot.
The headlights are already projectors, so just get teh conversion.
They are 2 product lines that Xenondepot uses.
Well, hope this helps
https://www.clublexus.com/forums/sho...d.php?t=264551
Here's a link for everything you pretty much need to know about bulbs, headlamps housings, HID conversions, and more. I think someone has posted this link but i'll just post it again just in case.
http://www.danielsternlighting.com/t...nversions.html
AFS = Adaptive Front Lighting System
The Adaptive Front Lighting System (AFS) helps illuminate more of the road in a turn. In a left-hand turn, the left headlamp will pivot up to 15 degrees (the right-hand headlamp remains pointed straight ahead) and in a right-hand turn, the right headlamp will pivot up to 5 degrees (the left-hand headlamp remains pointed straight ahead).
im thinking of putting in a Xenon Depot HID conversion kit for my headligth and fog light, does anyone know if thats a good brand, any comment or suggestions?? also my friend told me that my battery can't handle the HID headlight and HID foglight at the same time, is this true???
Xenon Depot has 2 lines
Xtreme: Uses asian components
XenonDepot: Uses all German Phillips components
Tell you the truth, if you saw a car with Xtreme pass you buy, and then one with XenonDepot, you couldn't even tell the difference.
If at a standstill, you would see maybe a little difference.
What you can do, is if you want both lows and fogs, get the XenonDepot for lows, and the xtreme line for fogs
JDM RICE
GX - 2nd Gen (2010-2023)
05-12-10 10:10 AM
