aftermarket sound system jl sound sweep or apline Alpine PXE-H650
Old 06-13-07, 02:37 AM
japanmade
japanmade's Avatar
Default aftermarket sound system jl sound sweep or apline Alpine PXE-H650
Anyone have istalled the JL clean sweep with ther nav/radio to connect to aftermaket amps. If so how does it sound and was it easy to hook up. Also Alpine is coming out with there version Alpine PXE-H650 this month. Does anyone know if this is better. I plan on installing all new Diamond Audio D9's, 2 rockford power T800.2 and T1000.1 (yes surf board amps) and 2 JL 10 W7's but need a low level clean signal. I would prefer to put a new HU but obviously everything is integrated. Any suggestions.
Old 06-13-07, 06:05 AM
effusion
effusion's Avatar
im getting my car done this week with cleansweep. Sigh, some ppl say the alpine is better since there are more adjusments you can make.
Old 06-13-07, 06:41 AM
japanmade
japanmade's Avatar
The problem with clean sweep is the volume control. There are 2 one master one slave. One on cleansweep and one for volume on stock HU- your choice. the problem is it allows more distortion because you are causing 2 different gain signals. This is why if anyone has the alpine system. Does this cause a problem. I have done this before on other sound systems when there are 2 volume controls to balance out. I wish apline wound have better info on this. But good luck on your clean sweep and let me know how it comes out. I would buy JL over Apline anyday
Old 06-13-07, 07:15 AM
effusion
effusion's Avatar
thats what made me get the JL cleansweep lol...
Old 06-13-07, 12:49 PM
Dj_AmtraX
Dj_AmtraX's Avatar
Cmusic,
Can you full us in on the Alpine?
Old 06-13-07, 04:05 PM
ABC
ABC's Avatar
Info on the alpine unit: http://www.alpine-europe.com/typo3/i...=pxe-h650&L=16
Old 06-13-07, 04:38 PM
Dj_AmtraX
Dj_AmtraX's Avatar
Looks like it is not avaliable for the U.S.
Old 06-13-07, 08:31 PM
nabisco
nabisco's Avatar
It's not out yet and I herd it has been delayed a few times.
Old 06-13-07, 08:45 PM
shern
shern's Avatar
Rockford Fosgate 3sixty. Do some research and you'll see how comprehensive this unit is.
Steve
Old 06-13-07, 09:32 PM
unit74
unit74's Avatar
I have the 3Sixty with a 10" Punch P3 and the BD500...
The only gripe I have is that the master volume no longer controls the bass. You can turn the volume up, but the bass does not change. You have to manually change the gain on the ****......
Look into the Audiocontrol LC6i for a cheaper solution that the Alpine, RF or JL line summing units....
Old 06-13-07, 09:51 PM
japanmade
japanmade's Avatar
Well check put crutchfield, they have it advertised, but no real deal info even the alpine euro web site.
Old 06-13-07, 09:53 PM
japanmade
japanmade's Avatar
the rockford sixty- you need a PDA to run the tunning as in EQ. the alpine can be adjusted through you laptop.
Old 06-14-07, 06:36 AM
rt350
rt350's Avatar
i have cleansweep with arc amps and woofers. it sounds so much better now. i don't hear any distortion. it sounds like my mark levison now has that extra punch it was lacking.
Old 06-14-07, 08:38 AM
japanmade
japanmade's Avatar
for those who have cleansweep. What volume control are you using. Whichever you are using as volume, close all windows and turn the volume all the way down. Do you hear any distortion, hissing, how about turning on your engine, does it get louder, rev the motor, does it whine with your engine. This is a common problem on previous setups, regardless of a good/bad ground. Any issues let me know
Old 06-14-07, 10:51 PM
Dj_AmtraX
Dj_AmtraX's Avatar
That is the reason why I am not getting the JL or 3sixty. Anyone have a link to the Alpine manual?
Quick Reply: aftermarket sound system jl sound sweep or apline Alpine PXE-H650
