TSB: ECU running too rich.....
I can't share you my TIS account, but I think they have daily pass for $10.
Unless you are local to San Jose CA... if so drop by.
http://techinfo.toyota.com/
See at first I thought it was my HIDs messing around with ECU but they didn't bring up anything regarding my headlights so he just told me that it threw a code regarding the ECU running to rich. I'll keep you guys posted but call your local dealerships and see if they have a TSIB on this issue.
Were you able to find anything regarding the ECU?
Tech Info Resource
Yes. TSIB EG002-07 for the automatic and TSIB EG006-07 for the manual. They will reflash the ECM to correct the problem.
Lexus Supports ASE Certification Page 1 of 21
Title:
TECHSTREAM ECU FLASH
REPROGRAMMING PROCEDURE
Models:
’01 – ’08 Applicable Lexus
Technical Service
Information Bulletin
March 5, 2007
SS002-07
Flash reprogramming allows the ECU software to be updated without replacing
the ECU. Flash calibration updates for specific vehicle models/ECUs are released
as field–fix procedures described in individual service bulletins. This bulletin details the
Techstream ECU flash reprogramming process and outlines use of the Technical
Information System (TIS) and the Calibration Update Wizard (CUW).
Flash calibration updates can only be applied to the vehicle/ECU combination for which
they are intended. ECUs have internal security that will not allow them to be programmed
with another ECU’s information.
NOTE:
Electronic Control Unit (ECU) is a Lexus term used to describe integrated
computerized devices responsible for managing the operation of a system or
subsystem. For the purposes of this bulletin, the term “ECU” is used as a generic
label for the following SAE J1930 standard references:
.. Powertrain Control Module (PCM)
.. Engine Control Module (ECM)
.. Transmission Control Module (TCM)
.. Or any other Lexus specific control unit
.. 2001 – 2008 model year applicable Lexus vehicles.
NOTE:
NOT all models are capable of flash reprogramming.
PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME QTY
N/A 00451–00001–LBL Authorized Modification Label 1
NOTE:
Authorized Modification Labels may be ordered in packages of 25 from the Materials
Distribution Center (MDC) through the Dealer Daily Dealer Support Materials System,
or by calling the MDC at 1–800–622–2033.
OP CODE DESCRIPTION TIME OFP T1 T2
N/A Not Applicable to Warranty – – – –
SPECIAL SERVICE TOOLS
Introduction
Applicable
Vehicles
Parts
Information
Warranty
Information
TECHSTREAM ECU FLASH REPROGRAMMING PROCEDURE – SS002-07 March 5, 2007
Page 2 of 21
REQUIRED EQUIPMENT SUPPLIER PART NUMBER QTY
TIS Techstream*
NOTE: Software version 2.00.008,
or later, is required.
ADE TSPKG1 1
NOTE:
Additional Techstream units may be ordered by calling ADE at 1–800–368–6787.
REQUIRED SPECIAL SERVICE TOOLS (SSTs) SUPPLIER PART NUMBER QTY DRW**
Digital Battery System Analyzer* SPX/OTC 00002–V8150–KIT 1 24
GR8 Battery Diagnostic Station* SPX/OTC 00002–MCGR8 1 –
* Essential SSTs.
** Drawer number in SST Storage System.
NOTE:
Additional SSTs may be ordered by calling SPX/OTC at 1-800-933-8335.
Techstream ECU flash reprogramming is a 4–step process:
1. Verify the vehicle’s applicability for recalibration and locate desired calibration file.
Vehicle applicability can be determined by the following methods:
.. Techstream ECU Reprogram Function
.. Techstream Health Check Function
NOTE:
Techstream will automatically search TIS for the appropriate service bulletin using the
current Calibration ID from the vehicle. Calibration file links can be found embedded
in the corresponding service bulletin.
.. TIS Calibration Search
.. TIS TSIB Search
NOTE:
TIS searches can be performed by picking Division/Model/Year, current calibration ID,
or VDS code.
Required
Tools &
Equipment
Process
Overview
Page 3 of 21
2. Connect the GR8 battery charger.
The GR8 battery charger includes a Power Supply Mode that maintains battery
voltage at 13.5 volts during ECU reprogramming.
3. Locate appropriate calibration ID and reprogram the vehicle ECU with Techstream.
Techstream uses the Calibration Update Wizard (CUW) application to open calibration
files and facilitate the ECU flash reprogramming process.
4. Affix the Authorized Vehicle Modification Label.
Modifications to ECU calibrations MUST be recorded and properly displayed on the
vehicle using the Authorized Modification Label.
The following steps describe how to properly flash reprogram an ECU using the
Techstream diagnostic application.
NOTE:
Ensure Techstream has been updated with the latest version of software.
A. ECU Reprogram Method:
a. Establish a vehicle connection.
b. Click the ECU Reprogramming button on the System Select tab (Figure 1).
Figure 1
Process
Overview
(Continued)
Operation
Procedure
Page 4 of 21
c. Select available ECU(s) from the Calibration Update Check List (Figure 2).
NOTE:
Multiple ECUs can be selected.
d. Click the green arrow button (bottom right of screen) to retrieve current
calibration ID(s) and check for available calibration updates.
Figure 2
Operation
Procedure
(Continued)
Page 5 of 21
e. Available calibration updates are indicated by a Yes in the Calibration Update
column (Figure 3). Click the Yes link to access the appropriate service bulletin
on TIS.
NOTE:
.. Prior to flash reprogramming, check applicable systems for DTCs and note any DTCs.
.. Clicking the Yes link will automatically launch TIS and perform a calibration search.
Figure 3
Operation
Procedure
(Continued)
Page 6 of 21
f. Log in to TIS. (If already logged in, skip this step.)
g. To access the calibration file, click the service bulletin link in the Document
Title column of the Calibration Search Result portlet (Figure 4).
NOTE:
Only Lexus Senior, Master, and DS Technicians may access calibration files.
Figure 4
Operation
Procedure
(Continued)
Page 7 of 21
B. Health Check Method.
b. Click the Health Check button on the System Select tab (Figure 5).
Figure 5
Operation
Procedure
(Continued)
Page 8 of 21
c. Choose desired ECU group(s) in the Health Check dialog box (Figure 6).
d. Click Next.
Figure 6
e. Click Continue to view Health Check results (Figure 7).
Figure 7
Operation
Procedure
(Continued)
Page 9 of 21
f. Available calibration updates are indicated by a Yes link in the Cal Update?
column. Click the Yes link to access the appropriate service bulletin on TIS
(Figure 8).
NOTE:
.. Note any DTCs stored in systems that will be flash reprogrammed.
Figure 8
g. Log in to TIS. (If already logged in, skip this step.)
Operation
Procedure
(Continued)
Page 10 of 21
h. To review the TSIB and access the calibration file, click the service bulletin link
in the Document Title column of the Calibration Search Result portlet.
NOTE:
Figure 9
Operation
Procedure
(Continued)
Page 11 of 21
A. Connect the battery charger to the car and turn it on.
B. Select Power Supply Mode by following the screen flow below (Figure 10).
NOTE:
.. Power Supply Mode is used to maintain battery voltage at 13.5 volts while flash
reprogramming the vehicle.
.. For details on how to use the GR8 battery charger, please refer to the GR8
Instructions Manual, located on TIS, Diagnostics – Battery.
Figure 10
Operation
Procedure
(Continued)
Page 12 of 21
3. Click the appropriate calibration ID (Figure 11) and reprogram the vehicle’s ECU
with Techstream.
A. After reviewing the procedures outlined in the selected TSIB, click the appropriate
calibration ID link by matching the vehicle’s current calibration ID to the Previous
Calibration ID in the Calibration Identification Chart.
NOTE:
.. Calibration files are embedded as live links in the service bulletin.
.. Some vehicles require special preparation — please review the selected
TSIB carefully.
Figure 11
Operation
Procedure
(Continued)
Page 13 of 21
B. Click Open to load calibration file information (Figure 12).
NOTE:
Techstream pulls calibration files as needed to ensure the latest calibration file is used.
Do NOT save calibrations locally on the hard drive or other media.
Figure 12
NOTE:
Errors during the flash reprogramming process can permanently damage the vehicle
ECU. Minimize the risk by following the steps below.
.. Battery voltage MUST NOT FALL BELOW 11.4 volts during reprogramming.
Confirm battery voltage is higher than 11.4 volts, but be sure voltage DOES NOT
RISE ABOVE 16.0 volts during reprogramming.
.. Turn OFF all vehicle accessories (e.g. audio system, A/C, interior lights, DRL, etc.).
Do NOT add to or significantly change the vehicle’s electrical load
while reprogramming.
.. Confirm the hood is open and ensure under hood temperature does NOT exceed
158°F (70°C).
.. Confirm cable connections between the vehicle and Techstream are secure.
.. Do NOT disconnect or turn off Techstream or vehicle ignition during reprogramming.
.. Set parking brake.
.. Complete ALL flash calibration updates provided for each ECU.
.. If the battery’s state of charge or capacity are in question, test with SST. No.
00002–V8150–KIT “Digital Battery Analyzer”, and follow TSIB No. PG001–06,
“Battery Maintenance for In–Stock Vehicles & Pre–Delivery”.
To ensure stable battery voltage, a battery charger MUST be connected so:
.. Voltage does NOT fall below 11.4 volts.
.. Voltage does NOT exceed 16.0 volts.
Operation
Procedure
(Continued)
Page 14 of 21
C. Click Next to start the calibration update process.
Figure 13
D. Select Techstream VIM as the desired programming device. Then click Next.
Figure 14
Operation
Procedure
(Continued)
Page 15 of 21
E. Confirm the following:
.. PC is connected to VIM.
.. VIM is connected to DLC3 connector.
.. Ignition is ON and engine is OFF or Ready Off (hybrid vehicles).
Figure 15
F. Verify correct current calibration and new calibration information.
NOTE:
.. The total number of calibration IDs in the calibration file corresponds to the number
of reprogrammable processors in the ECU.
.. Each calibration file may contain up to three separate calibrations.
.. Figure 16 shows an example of the update procedure for a two processor ECU.
Figure 16
Operation
Procedure
(Continued)
Page 16 of 21
G. Turn ignition OFF.
Figure 17
H. Confirm the following:
.. Hood is open.
.. All accessories are OFF.
.. Battery voltage is above 11.4 volts.
NOTE:
Verify the vehicle is connected to a battery charger before continuing — If battery
voltage falls below 11.4 volts, ECU damage may occur.
Figure 18
Operation
Procedure
(Continued)
Page 17 of 21
I. Do NOT disturb the vehicle during flash reprogramming.
NOTE:
.. ECU flash reprogramming may take anywhere from 3 – 30 minutes per
calibration file.
.. Reprogramming time will vary depending on model and ECU communication
protocol. Vehicles using CAN communication protocol will reprogram much faster
(2 – 7 minutes).
Figure 19
NOTE:
.. If vehicle requires only ONE calibration update, then proceed to step N in this bulletin.
.. If vehicle requires a SECOND calibration update, then continue as follows:
.. For serial communication vehicles, go to step J.
.. For CAN communication vehicles, go to step L.
Operation
Procedure
(Continued)
Page 18 of 21
J. Cal 1 has completed the update process.
.. Turn ignition OFF for a minimum of 10 seconds.
.. Confirm ignition is returned to the ON position.
Figure 20
K. Confirm ignition is ON.
Figure 21
Operation
Procedure
(Continued)
Page 19 of 21
L. Do NOT disturb the vehicle during flash reprogramming.
Figure 22
M. Turn ignition OFF for a minimum of 10 seconds. Then confirm ignition is returned
to the ON position.
Figure 23
Operation
Procedure
(Continued)
Page 20 of 21
N. Confirm ignition is ON.
Figure 24
O. Confirm all calibrations were updated as specified in the service bulletin.
Figure 25
NOTE:
Some DTCs may have been set during the reprogramming process. Clear all DTCs
after restoring vehicle.
Operation
Procedure
(Continued)
Page 21 of 21
4. Affix Authorized Modification Label.
A. Using a permanent marker or ball point pen, complete the Authorized
Modifications Label and attach to the vehicle (Figure 26). The Authorized
Modifications Label is available through the MDC, P/N 00451–00001–LBL.
Figure 26. SAMPLE OF COMPLETED AUTHORIZED MODIFICATIONS LABEL
THESE MODIFICATIONS HAVE BEEN APPROVED
AS APPROPRIATE BY EPA AND CARB
DEALER CODE: DATE:
CHANGE AUTHORITY: TSIB EG002–05
34845100, 54813100
89661–48470
Replacement
ECU Part Number
Calibration ID(s)
TSIB or Campaign Number
Dealer Code Date Completed
THE FOLLOWING MODIFICATIONS HAVE BEEN MADE:
31301 8/2/06
B. Attach the label under the hood in the location determined by the specific vehicle
TSIB or Campaign.
NOTE:
Wait 60 – 90 seconds for ink to set before handling.
Operation
Procedure
(Continued)
Title:
Models:
Technical Service
March 5, 2007
SS002-07
NOTE:
NOTE:
NOTE:
Introduction
Applicable
Vehicles
Parts
Information
Warranty
Information
Page 2 of 21
TIS Techstream*
ADE TSPKG1 1
NOTE:
* Essential SSTs.
NOTE:
NOTE:
.. TIS TSIB Search
NOTE:
or VDS code.
Required
Tools &
Equipment
Process
Overview
Page 3 of 21
NOTE:
Figure 1
Process
Overview
(Continued)
Operation
Procedure
Page 4 of 21
NOTE:
Figure 2
Operation
Procedure
(Continued)
Page 5 of 21
on TIS.
NOTE:
Figure 3
Operation
Procedure
(Continued)
Page 6 of 21
NOTE:
Figure 4
Operation
Procedure
(Continued)
Page 7 of 21
Figure 5
Operation
Procedure
(Continued)
Page 8 of 21
d. Click Next.
Figure 6
Figure 7
Operation
Procedure
(Continued)
Page 9 of 21
(Figure 8).
NOTE:
Figure 8
Operation
Procedure
(Continued)
Page 10 of 21
NOTE:
Figure 9
Operation
Procedure
(Continued)
Page 11 of 21
NOTE:
Figure 10
Operation
Procedure
(Continued)
Page 12 of 21
with Techstream.
NOTE:
TSIB carefully.
Figure 11
Operation
Procedure
(Continued)
Page 13 of 21
NOTE:
Figure 12
NOTE:
158°F (70°C).
Operation
Procedure
(Continued)
Page 14 of 21
Figure 13
Figure 14
Operation
Procedure
(Continued)
Page 15 of 21
Figure 15
NOTE:
Figure 16
Operation
Procedure
(Continued)
Page 16 of 21
Figure 17
.. Hood is open.
NOTE:
Figure 18
Operation
Procedure
(Continued)
Page 17 of 21
NOTE:
calibration file.
(2 – 7 minutes).
Figure 19
NOTE:
Operation
Procedure
(Continued)
Page 18 of 21
Figure 20
Figure 21
Operation
Procedure
(Continued)
Page 19 of 21
Figure 22
to the ON position.
Figure 23
Operation
Procedure
(Continued)
Page 20 of 21
Figure 24
Figure 25
NOTE:
Operation
Procedure
(Continued)
Page 21 of 21
DEALER CODE: DATE:
34845100, 54813100
89661–48470
Replacement
ECU Part Number
Calibration ID(s)
31301 8/2/06
TSIB or Campaign.
NOTE:
Operation
Procedure
(Continued)
Tech Info Resource
tjschraf
01-10-14 05:53 AM
