Fact or Myth: A car gains power after break-in? (Dyno numbers inside)
Old 06-20-07, 01:42 PM
cancellino
cancellino's Avatar
Interesting Post...Thanks
Old 06-20-07, 03:56 PM
Technique
Technique's Avatar
Originally Posted by caymandive
You need to get your charts with SAE correction turned on and make sure the smoothing factor is the same for both sets of runs. This will eliminate the weather variables. From what you have posted, we can't say either way how the car has responded with a few thousand miles put on her. Something else that may help is to get the runs overlapped from both dyno sessions. You may have gains in the power band, but not at peak numbers. See if you can get the shop to load the runs on a memory stick and load the files into Winpep you will have a more accurate representation.
If your car is still stock with 15,000 miles or more you may want to dyno again down the road. I don't think driving 5900 miles will yield any real measurable change in the engine power. Too many variables when measuring such small changes in power.
I'm pretty sure smoothing was on for all runs... They used the same profile for all 6 runs... And before my very first run they created a folder for me and used the IS350 profile...
Old 06-20-07, 05:09 PM
Yang1815
Yang1815's Avatar
I personally think that there are too many variables and there are not enough runs for a statistical calculation to verify significance even if the variables did NOT exist.
juanmedina
IS F (2008-2014)
21
03-30-16 04:20 AM
ajmccarrel
Performance & Maintenance
43
04-23-12 01:26 PM
ff_
11-16-06 05:37 AM
kreativ
08-06-02 02:20 PM
Quick Reply: Fact or Myth: A car gains power after break-in? (Dyno numbers inside)
