OEM spoiler -- no drilling install?
Old 06-28-07, 02:56 AM
SC3coupe
SC3coupe's Avatar
Default OEM spoiler -- no drilling install?
Please report results. Any "play" in the spoiler at all?
Can the 3M tape alone stand the Cali heat?
Old 06-28-07, 04:13 AM
MrMark
MrMark's Avatar
6 months here....no problems....
Old 06-28-07, 06:38 AM
gsrthomas
gsrthomas's Avatar
I drilled mine. I say do it right the first time. Not like you are going to ever take it off right?
Old 06-28-07, 07:23 AM
ISbb
ISbb's Avatar
almost a year now no problems at all... X fingers make sure you use hot gun when you install it by the 3M tapes to make them extra storng...
Old 06-28-07, 07:27 AM
SC3coupe
SC3coupe's Avatar
If I drill how can I rust proof the holes?
Old 06-28-07, 09:02 AM
gsrthomas
gsrthomas's Avatar
I just used alittle bit of silicone around the screw. Thats it. I do not think you need to use anything.
I installed a rear oem spoiler on my moms Toyota Highlander 5+ years ago. I didnt use any rust proof materials and its fine even today.
You are in CA I wouldnt worry about rust.
Old 06-28-07, 09:48 AM
combfilter
combfilter's Avatar
stock tape that came on spoiler and a little extra 3m tape. i've had the car to 140mph, in the freezing cold , and texas heat. No problems. There is no need to drill into your car.
Old 06-28-07, 10:16 AM
LexIS250SS
LexIS250SS's Avatar
I installed mine using the no drilling method! No extra tape.. No problems so far!
Old 06-28-07, 03:10 PM
DanTheMans
DanTheMans's Avatar
Is there a DIY on how to do the install without drilling anywhere? Haven't been able to locate one...
Old 06-28-07, 03:48 PM
combfilter
combfilter's Avatar
search "spoiler" under advanced search and you should be good.
Old 06-28-07, 04:39 PM
DanTheMans
DanTheMans's Avatar
Checked... no luck
Old 06-28-07, 08:26 PM
combfilter
combfilter's Avatar
Originally Posted by DanTheMans
Checked... no luck
i used the same search function you did. keyword spoiler in the 2nd gen is section.
https://www.clublexus.com/forums/sho...hlight=spoiler
Old 06-28-07, 08:51 PM
Akatsuki
Akatsuki's Avatar
i don't think you should drill it because what if you want something down the road later on? just use the tape method imo
Old 06-29-07, 02:49 PM
DanTheMans
DanTheMans's Avatar
Ok I just finished doing this, no drilling, and you guys weren't lying VERY easy!
Old 06-29-07, 03:34 PM
combfilter
combfilter's Avatar
actually we were lying. It's a cruel joke we like to play on all the n00bs. Your spoiler is going to go flying off next time you hit 75mph.
Quick Reply: OEM spoiler -- no drilling install?
