Last edit by: IB Advertising
Browse all: Exterior Guides
- Why Won't My Power Windows Go Up After Disconnecting Battery?
Guide to diagnose trouble and recommended solutions
Electrical HELP!!! (Windows won't roll up after battery disconnect)
#47
Lexus 470 Power window problem
Hi there,
I replaced my 2003 GX 470's battery. All my power windows except the driver-side window now will not work at all after replacing the battery. I cannot move them from the driver side or when directly using the switch at the window.
We checked the fuses and they are fine. Why did my windows stop working completely after the batter change and how do I fix it? The instructions will not help me since my windows do not move and are not blinking.
Mahalo for any help!
Sean
Sean
#48
I have a 2007 IS350. OEM battery lasted 7 years! Just changed it and found power window reset on Page 46 of the manual. In the Index, look for Power Windows - then it says to roll each window down half way, using the switch for that window. Then roll it up and hold it up for 1 second after the window is all the way up. The LED on the switch will change from blinking to constant-on after the successful reset. I did mine with the engine running and it worked on the first try.
allen
allen
#49
Thank you all for contributing to this thread! Had to pull my battery yesterday to install a pain in my *** battery tie down. Then when I went to roll the windows down of coarse they didn't want for work! Glad I searched!
#50
#52
#53
I Love You!
Love u guys! i had this problem for a while now and also was told it was my sunroof motor. i did the reset procedure and everything works i always had to help the sunroof close and it was embarrassing! i knew i was hurting the engine but now im not THANK YOU!
#57
#58
The back windows has no switch in is250 C convertible
How do I reset the small back windows? They don’t have designated controls. I only control them from the drivers side power switches. I was able to reset the front windows but the back.
This is the drivers side
This is the back window with no switches
#59
Protholl (01-08-24)
#60
Do the rear windows on the convertible even have auto-up and auto-down function? The labeling on the window switches that you posted show that only the front ones do.
JOROB
05-05-08 11:22 PM
