Mobil 1 Extended Performance oil change interval
#32
I myself am on the same boat as some of the people asking questions on this thread. I would like to use Mobil 1 in my recently purchased 2008 IS 350, but am wondering how to go about longer oil changes.
caymandive's suggestion here (and Knightshade's suggestion on my.is) are how I will probably go:
I've never done my own oil change before but will probably start now. Thanks brel523 for this:
Ah, thanks for this. I had always wondered why you couldn't just get a better filter to go longer with the Mobil 1 oil's extended life.
That cost of oil is pretty significant though right? You're saving $40 or so would be my guess - how many quarts of Mobil 1 would you need?
Lexus recommends those viscosities not just for cold start performance, but also for better fuel economy. As I recall, the language in the owner's manual says that 10W-30 can be used if 5W-30 isn't available, but they recommend switching back at the next change. From the Blackstone UOA reports that folks have posted, it doesn't look like there is any need to fear depleting the viscosity improvers in the 5W-30 and 5W-20 grades even with extended drain intervals.
ah, thanks for this clarification.
Spin, here is a link to my first oil change experience and DIY guide.
It's really easier than it looks/sounds and WAY cheaper than the dealer.
https://www.clublexus.com/forums/sho...d.php?t=276707
Since I would have to drive up on ramps, get under car, remove oil filter and let drain, put it all back together. Why wouldn't I just change the oil while I'm under there(other than cost of oil)? Removing one more bolt is a breeze and I already have oil container there.
I guess I'm saying, if I go to all that trouble to change the filter at 5k, I mind as well change the oil. Other than cost of oil, am I missing something?
