System In The 07' Is250
I was interested in placing a 12" MTX 7500 and a MONO D Class Amp in my car with the stock deck. I know I don't have the ML package. I tried to do some research on this from past threads so I don't bore or anger my fellow members to death. The only thing I found was this:
**all you need to do is tap into the low level signal at your factory sub amp-- it will be crossed over where it needs to be --
You can disconnect it's power cables and use it's remote turn on and low level signals for the new amp--
Just buy some standard rca cables, cut the ends off, and connect the center pole as the pos. signal, and the outer part of the connector/jack will be the signal ground--
For the sub amp it should only have a single positive and a signal ground, so you will only need to connect that into the left rca input on your amp--
This will work flawlessly-- You'll be glad you know me--
No need for a speaker line converter-- just adds one more component that may introduce noise into your system--
Now if this is correct I would need a wiring diagram for my factory amp so I know what wire is what. I would even love some picks of a self install also to get an idea. PLEASE HELP!
Kane007
04-19-21 10:02 AM
shahir18
04-16-14 08:45 PM
98023IS250
03-27-10 10:11 AM
