Parking Brake Problem
I parked on a bit of a steep hill the other day and when I put the e-brake on and proceeded to get out the car moved forward quite noticeably (like 1-2 feet). I also noticed that if I sat in there and moved around inside, the car would make a weird noise and again slide forward a little bit.
This isn't normal, right? The hill was pretty steep but still that's no excuse for the e-brake to be hanging on by a thread. Let me put it this way, even though I had the pedal fully pressed, the car acted as if I'd applied the brake only partially.
Any insight is appreciated.
Super Moderator
If you've applied the parking brake firmly and it still isn't holding, I'd bring it to the dealer. Perhaps it needs to be adjusted.
Also, I presume you have a manual tranny, as with an automatic in Park the transmission pawl would lock the rear wheels in less than 1-2 feet. With a manual, it's a good idea to leave the car in 1st gear rather than neutral when parked, in case the parking brake slips.
Have your dealer adjust your hand brake. You shouldn't have to pull the brake all the way to the stops to get maximum brake. It should be adjusted so about 3/4 travel on the handle gives full effect. It is a simple adjustment and all handbrakes need to be adjusted from time to time. And all manual cars should be put in gear (1st or reverse) when using the e-brake.
I actually have the auto box on my 250. Maybe 1-2 feet was an overestimate but I just wanted to differetiate this from the usual little jolt you get if you're on a steep hill.
Anyway it's weird because the car moved really considerably when I first applied the brake and every time I'd move around inside it made this creaking noise as if it was about to let go and roll down the street.
I guess I'll have it looked at. Just wanted to make sure it's a valid problem and not just me nitpicking.
I had the same issue with mine, though i drive a manual, i did bring it to the dealers attention however, but after they checked it out they said that it cannot be tightened any further. so i still have to apply it 100% to make sure it doesnt move. strange i find.
The emergency brakes are seperate internal drum brakes on the inside the rotors. I have a rattle in the rear and had the car in twice. They insist the noise is the emergency brake assembly. I will bring it back Thursday for the third time. They are having their best tech adjust them. They are telling me the adjustment is really critical and has to be just right or it will rattle over light bumps. We will see!
Koz
Koz
I have an IS250 AWD and i had my parking brake doing the same thing as you. I don't even need to be on a hill for it to make the sqeazking noise. if it is a little bit slanted and i apply the parking brake then move around the in the car it would squeazk like it is not holding every well. First time i took it in they said that the parking brake was not adjusted right at all. Second time same problem, they said they were heavy glazing on the rotor so they have to re-surface my rotors. Now the problem is kind of gone but not quite. it will squeak once on a steep hill and goes away. thinking of taking it in the third time. I think it's getting louder again. have your look at by the dealer
Koz
Koz
