Poor starting performance
Old 07-11-07, 07:17 AM
hadeed350
hadeed350's Avatar
Default Poor starting performance
Hi all...looking for feedback. I picked up my '07 IS350 in May. After the first 1000 miles I started noticing that my car wouldn't start quick after pushing the button (typical start time is 1~2sec after you push the button). It sounds like the car is hesitating and wont turn over. This doesn't happen on a "cold start" after the car sat overnight. I typically get the problem after I've driven for 15mins and then restart after a few hours.
Dealer can't reproduce the problem, therfore cannot fix the problem. I only have 3000 miles on the vehicle, any suggestions!?!
Old 07-11-07, 07:23 AM
nehal51086
nehal51086's Avatar
i cant say that i have noticed that with my car...ive only had a problem with the ignition once...i went to start it and then the cluster started flashing and the screen read "Start Faliure"...but it has not happen since....
Old 07-11-07, 09:02 AM
phatboyc
phatboyc's Avatar
Your car is in a learning curve. It will be all over soon.
Old 07-11-07, 09:45 AM
al503
al503's Avatar
I've never had this issue. If it's not too much trouble, set up an appointment now. Otherwise, wait until your 5000 mile service comes up and have them take a look at it then. Something doesn't sound right.
Old 07-11-07, 12:03 PM
ShoFly
ShoFly's Avatar
Originally Posted by hadeed350
After the first 1000 miles I started noticing... I only have 3000 miles on the vehicle, any suggestions!?!
2000 miles learning curve? That seems a bit long.
Old 07-11-07, 12:06 PM
k_dizzle
k_dizzle's Avatar
wow! interesting...nothing like that has happen to my 06 yet....
Old 07-11-07, 01:24 PM
Bichon
Super Moderator
Bichon's Avatar
I've not had this issue either.
Make sure the dealer documents your complaint in their records. Hopefully you'll figure out what specific conditions cause it to happen, so that you'll be able to reproduce the problem for the dealer.
Old 07-11-07, 01:34 PM
ben_r_
ben_r_'s Avatar
I havent had that issue either, but if it were mine it just keep driving it and forget about it until it gets worse or no longer starts. Then you can take it in and they will for sure fix it. Either way just keep in mind that its all under warranty!
Old 07-11-07, 04:44 PM
Gernby
Gernby's Avatar
I would start documenting the starts with a video camera (good starts and bad starts). That way they can see proof that it is actually doing it.
Old 07-11-07, 07:50 PM
phatboyc
phatboyc's Avatar
Mine had around 5000km when the engine staled right after starting. This happened 3 times in the same month. This was after the dealer had done a complete reset. Since it hasn't happened since, now at 13000km, I believe it was all about the CPU learning...
Old 07-11-07, 08:28 PM
Gernby
Gernby's Avatar
There's a big difference between stalling and not starting.
Old 07-12-07, 05:26 AM
Bichon
Super Moderator
Bichon's Avatar
By "hesitating", do you mean that the engine is turning over very slowly, like the battery is weak? Or is it not cranking at all? Or is it cranking normally, but just not starting?
Old 07-12-07, 11:25 AM
hadeed350
hadeed350's Avatar
Bichon,
Yes my car is cranking but not starting normally. Yesterday I documented all the bad starts (gotta love video phones!). I'm planning on taking it to the dealer this weekend. I don't think there is a learning curve (my '06 IS350) didn't have ANY starting problems. Sounds like I have a unique case
Old 08-08-07, 12:49 PM
hadeed350
hadeed350's Avatar
wanted to update you all. cars been in the dealer 3 times, they've replaced the fuel pump and all fuel injectors. still having a problem....you think i qualify for lemon law!?!
Old 08-08-07, 01:13 PM
Gernby
Gernby's Avatar
I thought the lemon law required something like 7 unsuccessful trips to the dealer. I'm not sure, but it may also vary by state.
Glad to hear that you at least convinced them that it is a real problem.
Quick Reply: Poor starting performance
