Is it worth $165 for 10,000 mile maintenance???
It all depends on what $165 means to you and how long it takes to earn that much. Bill Gates probably has socks that cost more. If you're not Bill Gates, you might consider your other options..Like changing the oil yourself or finding an independent shop to do it (I would avoid the quick lube places)
JM Lexus is doing a synthetic blend oil change and wheel balancing for $39.95. So yeah, $165 for same is a little much.
What I should have said is that if it was my car, I would be putting in better oil than either the shop or dealer would.
It's depend on what car you have. If you have awd then you can rotate your tires.
You should do it yourself and save money. Go to walmart buy oil, go to toyota dealer and buy oil filter. Go home do it yourself, or ask your friend, who knows how to change oil to do it for you.
If your car is awd, then you can rotate tires by yourself. If it is rwd, then forget it.
All the "inspection" are useless. They just take a quick look at your fluids, and all that crap...
I will be changing my oil for the first time in about a month here, once I hit 10k miles... I'll do a full blackstone analysis for you guys too...
goto35
RX - 4th Gen (2016-2022)
20
01-10-19 04:26 PM
