Auto tilt away of the steering wheel
I saw the tilt steering wheel option on the LPS. The manual does not say how to disable it. it is strange that I could not change the auto tilt-away option by myself, but I can change the door lock options.
It seems kind of stupid that Lexus doesn't make it possible to set the LPS yourself. Some of the stuff that you have to go to the dealership for is kind of silly, like the auto headlight sensitivity. Is this just a way for them to extract more money out of their service department? And, for the few things they do let you change (like the door locks), they should really just centralize everything under some easy to use intuitive interface like a menu system. Anything that can be customized should all be together, and not scattered across secret key presses, going to service to set the LPS, or the satellite switch (for the tach and speedo warning lights).
No--there is a setting that the wheel will move up and out of the way for easier ingress/egress. I thought it was a setting that only applied when you had a power tilt/telescope wheel, but the LPS sheet doesn't specify.
