5W-30 to 5W-20 recommendation
Hi all,
I have done searches both on the forum and google but cannot find the actual TSIB pdf from Lexus that recommends 5W-20 for the IS instead of 5W-30. Could someone please be kind enough to post it? Thank you.
Thank you very much! Just got the oil change done this afternoon at a Toyota Dealer; brought in my own oil (Mobil 1 5W-20) and filter, was charged $9 for labor.
I did have a quick question though, for anyone to respond to. The manual says for an oil change the drain and refil amount is 6.6 quarts, and I watched the tech drain the oil out completely and refil with 6.6 quarts (this is a small Toyota Dealership and they are very cool with letting customers in the bay and watch them work on their cars) However, when I check my dipstick, it reads slightly above the top notch, about a quarter inch. Is this normal?
If it were me, I'd drain out about half quart or so. It could be that they got in a hurry/impatient to let all of the old oil drain out but a 1/4" over the full is a lot.
I don't think I've ever needed to put 6.6 qts back in after draining. I usually drain it (while hot) with the driver side of the car raised higher than the passenger side until it quits dripping then fill it with 6 qts. That usually results in the level being right in the middle of the tick marks on the dip stick.
Great deal.....I wouldn't worry about it, but YMMV.
So is this TSB saying 5W-20 is better for the IS (in terms of mileage, cold start, etc) than the 5W-30?
Are there any more technicalities to changing to 5W-20 that someone could explain to me please?
Thanks!
Thanks!
what does the dealership warranty on service...
I mean what do they cover, like free oil change til certain miles? or no...
I got the car in Houston, SW..
Just wondering.. the car only have like 7k on it..
