Uh oh... Please Help...
Old 07-28-07 | 02:23 PM
s6 4rings's Avatar
s6 4rings
Default Uh oh... Please Help...
I was driving my car today, and at a light I bumped it down into 1st gear manual mode and hit extreme redline in 1st gear *forgot to shift, as I'm used it shifting for you if you accidentally forget in other auto cars"... Am I in trouble? Is there a fuel cutoff, or rev limiter even up that high to prevent engine damage? I'm WORRIED.
I wish I had my 6spd S6 back.
Old 07-28-07 | 02:31 PM
CWS's Avatar
CWS
"Extreme redline" = what?
You must have also "accidentally" bumped the max gear number down to 1, too, right? If not, then it won't "extreme redline" when you take off.
Old 07-28-07 | 02:33 PM
ABC's Avatar
ABC
CL Folding 100000
I was going to comment, but I'll just bite my tongue...
Old 07-28-07 | 02:34 PM
jimmyjazz's Avatar
jimmyjazz
There is a rev limiter.
Old 07-28-07 | 02:54 PM
DRivera250's Avatar
DRivera250
i don't understand how this could happen every time i switch it to sports mode it always selects 4th gear as its highest gear to go to.
Old 07-28-07 | 03:08 PM
s6 4rings's Avatar
s6 4rings
Thank you Buford.
And... I bumped into 1st i meant.. and redlined and stayed there for a split second, and forgot to upshift... so yeah, screwed or not ya think?
Old 07-28-07 | 03:13 PM
dspIS250's Avatar
dspIS250
the IS has so many safety features that i don't think anything serious could have happened to your car. the IS is about as far from a raw sports car as you can go so it's always thinking for the driver. i used sports mode one time, but it wasn't as efficient as putting it in "D" so i don't use it anymore.
PNice972's Avatar
PNice972
you will be fine.
Old 07-28-07 | 03:15 PM
s6 4rings's Avatar
s6 4rings
Thanks again dpIS250, and PNice972
Old 07-28-07 | 10:25 PM
FiveOhNine's Avatar
FiveOhNine
Coming from a 6sp you should know that the only real way to over-rev is to go from 6 to 2 or similar misshift. This bypasses the rev limiter and over-revs which can cause lots of problems for your entire drivetrain.
This just isn't possible with a slushbox.
Old 07-28-07 | 10:36 PM
ben_r_'s Avatar
ben_r_
Ha Ha slushbox!!! LOL thats a funny term!
Old 07-28-07 | 11:37 PM
javyLSU's Avatar
javyLSU
2IS OG
That's because almost every speed is possible in the A760E's 4th gear:
As you can see, you have to be going over 109 mph for the transmission to not let you into 4th gear. It's almost fail-safe.
Oh, and to the OP - the throttle is electronically limited at 6750 RPM.
Javier
Old 07-29-07 | 01:19 AM
y2ks2k's Avatar
y2ks2k
CL Folding Freak
CL Folding 1M
Heheee, even with a stick like my long old del Sol VTEC, the red line cuts the engine (8200 RPM). That B16a wound up very fast and needed to stay high for power and I was 24 which pretty much meant I was bouncing off it 50 times a day for the entire 40000 miles I had it. I've bounced off the rev limiter on my IS350. I could probably bounce off it just as much and not have any problems at all.
Old 07-29-07 | 09:37 AM
FiveOhNine's Avatar
FiveOhNine
Yup, that's what it's there for. I wouldn't spend all day up over 6k, but hitting occasionally won't hurt anything.
Old 07-29-07 | 09:47 AM
Bichon's Avatar
Bichon
Super Moderator
Which begs the question, what happens if you flip the shift lever from "Drive" to sport mode when traveling 110 or faster? And no, I don't recommend anyone here be foolish enough to try it.
