Last edit by: IB Advertising
Browse all: Interior
- How to Install XM Satellite Radio
Step by step instructions for do-it-yourself repairs
DIY: 2007 ISX50 OEM XM Satellite Radio Install
#136
So I did this last night and activated my XM online and I have refreshed it 3 times and I still only get the preview channel and weather/emergency channel. Does anyone have any suggestions?
#138
#141
Just intsalled on my 2009 IS 250. Same issues as everyone else, the wiring harness is just a ***** to tuck in. Other than that, flawless. Head unit is pretty lame though. I should have got the nav.
#142
I just installed the XM tuner in my wife's '09 IS 250 (she fought me tooth and nail by the way), and between the instructions on this post and the instructions from Sewell Lexus in Dallas, it was a breeze. It took me a little over 2 hours to get it installed and put everything back together and my wife is finally happy (for now).
Good work on these instructions. Very helpful stuff.
Mark
P.S. The promo codes for Sewell don't appear to be working anymore.
Mark
#145
I just installed the XM kit on my '06 350 with ML and Nav. I got the kit from Sewell with a ClubLexus discount. All said and done I think it was a hair over $300. I followed sjgIS350's suggestion and mounted my antenna inside the glass next to the brake light (page 7). By far the hardest part of the install for me was getting the antenna wire threaded through to the inside, but I just had to take my time and be patient. Also, I did not remove the brake light completely, rather just pulled it out of its mount, so that may have made a difference. My windows are tinted (~20%) and so far I've not had any signal issues. I also have the Mark Levinson, and ngl1145 is correct (page 8) on the order of the harness plug-ins. You use the outer two plugs on the amp--not the 1st and 3rd, but the 1st and 4th. Other than that, this write up is a great walk through. BTW, you don't have to remove the lining on the trunk lid if you install the antenna inside. Thanks to everyone who posted before for the advice! Great work guys!
#149
Does anyone have the part number and price for the '06 trunk mount (rear glass) antenna? I have the original front windshield antenna and the reception fades in and out a lot. Hoping the rear mounted one will resolve this. I'm at work and can't open the .pdf I've left posts & emailed Darrel at Sewell for almost a week with other questions with no reply.....
#150
I would like to know if the same kit works for the gs 300 2006. My radio has the sat button but when I push it it goes to am. Is there a kit for this car that you know of?
Thanks!
Thanks!
