Last edit by: IB Advertising
Browse all: Interior
- How to Install XM Satellite Radio
Step by step instructions for do-it-yourself repairs
DIY: 2007 ISX50 OEM XM Satellite Radio Install
#106
Thanks member Ben R, I wanted to know how that instal was done. I was going to buy that tuner box and do it myself as well. Your directions will make me do that now. Furthermore, thanks for posting the window controls. I would have freaked out as well. This must be due to the ant-pinch technology and the sensors re-setting themselves.
I used the Lexus pdf instructions without looking at the DIY and I was fine. The Lexus one is well written. Nothing your average joe can't do.
#107
Hey, glad the write up is still helping people. Its been almost 6 months since I did that install and still havent had one hiccup with my XM system.
#111
I just did the install today on my IS-F with Mark Levinson system. I did notice that with the IS-F Mark Levison, the cables that you have to connect are slightly different than the way the instructions say or even this FAQ says. There are 4 connectors that are connected to the amp.
Assuming looking directly into the trunk, the amp is to the right side.
The connectors have the following setup
(Mark Levinson)
Connector 1] Remove and connect to harness
Connector 2]
Connector 3]
Connector 4] Remove and connect to harness
In the FAQ's for the standard radio, connectors 1 and 3 are the ones removed and hooked up to the harness. Figured I'd mention this to make it easier for those who do this with the Mark Levinson.
(Mark Levinson)
Connector 2]
Connector 3]
#113
Ben,
This is very helpful. I am going to be installing Sirius using the shark fin antenna next weekend. I wasn't sure how to remove the trunk and where that antenna (shark fin) connector was.
Thanks,
Mike
Thanks,
Mike
#115
Thanks!
Glad I could be of help ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Ha! Yea I do the same thing.
#116
I will add this to the write up, thanks for the info!
#118
#119
This is a really great write up. I have ordered my XM radio kit and plan to install it this weekend.
I do have a question for those that have done this installation. I realize that disconnecting the battery will require the windows to be re-initialized. But will I also lose my phone book entries and my stored nav destinations?
#120
