yes rubs on dips, what bracket are you referring to?
The bolt that holds the bumper. If you just installed the springs, it wont rub for now but after a week or 2... ouch. Cause I see that your offsets for the front is aggressive like mine.
have not had 4 passengers in the car with this setup. i would assume not because i shaved the 1/4 inner fender lip in the rear.
I'm getting some rubbing in the back during dips on the freeway at high speeds. I'm running an 8.5" rim in the back with a 245/35-20 and 15mm H & R wheel spacers. I just ordered a set of 255/35-20 for the rear and I anticipate I will rub even more. I will probably swap the 15mm spacers out for a set of 5mm.
How much did you take off that inner lip on the fender?
i will try to post a pic later. to get a good shot i must life the car with a jack. let me say one thing.. its verrrry time consuming to do what i did with the rear fender lip. i am very **** and spent hours performing this job for it to come out perfect.
