Radar Detectors
Radar Detectors
Far be it from me to encourage people braking the law, BUT if a guy were to want to purchase a radar detector which do you reccomend? Best overall, bang for the buck etc..
thanks
sorry about the double post!
thanks
Found this on the Valentine 1 web site:
Mounting high on the windshield reduces the effect of sunlight reflected from the hood, which increases the detector's ability to find weak beam fragments. Daytime warning sensitivity is completely dominated by how one manages the sunlight issues.
Mounting high behind the tint band may reduce the laser signal somewhat, but it reduces the sunlight contamination by the same amount. The result is an unchanged laser-to-sunlight ratio from the scene beyond your vehicle, but with reduced hood reflections owing to a higher vantage point—a net gain. Only in the dead of night would a just-below-the-tint-band mounting position be beneficial.
The downside of high mounting is the move away from the most common aiming points. This means that in bright sunlight, you may miss the occasional direct hit from very close range—no detection at all! But that's possible with a low mounting as well, just not as often.
Hey guys. I have had both and I am telling you that my escort 8500 x50 is better then my v1 was. Better in the sense that it doesn't false alert as much. I liked both, so don't get me wrong. I think one more thing I like about my escort is that its blue. Just kind of looks cooler.
If you have more then 200.00 (which is the price on craigslist for either radar) You can go big baller with the escort 9500. It has gps to make where a false positive is and remembers that location the next time you drive by it. If the signal is the same frequency it wont go off, however if a cop all the sudden decided he was going to radar close to where you always false positive, it will detect that change and then alert.
Yes also you want to mount around the middle of your windshield. Especially for laser.
Radars are well worth the money. My escort has already saved my azz 3x's. Well worth the 175.00 i paid for it.
