Auxiliary Audio Input Port Noise TSIB L-AU001-07 Finally Released!
Old 12-19-12, 01:31 AM
  #121
CalitriSC
CalitriSC's Avatar
Originally Posted by ydnandy
nice find on the new TSIB! Glad you were able to get it fixed.
For those out of warranty, i was using this cable from as my aux cable. It has the ground loop isolator built inline, so no extra pieces. Got rid of all the engine noise and was cheap.
http://www.amazon.com/Kensington-Red...2620934&sr=8-1
sweet ordered this for my 08 F
Old 02-21-14, 11:05 PM
  #122
metaleckz
metaleckz's Avatar
if i bring this at lexus, will theyfix it for free? i have a 2009 lexus is350
Old 01-31-15, 11:20 PM
  #123
Golfer2000
Golfer2000's Avatar
Originally Posted by Initial_K
Anyone got the dealer to fix this out of warranty
Just picked up my MY08 with this issue. 15K miles but an 08 I doubt they will play. anyone have any luck?
Old 07-12-16, 10:22 AM
  #124
Gohanburne
Gohanburne's Avatar
I can find the new AUX port, but I am having some trouble finding the wiring harness and condenser. Anyone got a good, reputable parts website that might have it?
Old 05-13-18, 01:17 PM
  #125
Toxicxk23
Toxicxk23's Avatar
Resurrecting an old post.
I never got this TSIB done but would like to. I used to use a in line filter device off Amazon but I recently had an incident where my bluetooth transmitter device shorted or something and literally caught fire. Every since then, my AUX port will not work unless something is plugged into either power outlet and drawing power (i.e. charging a phone or a bluetooth transmitter). Also, every time I buy a new in line filter, the speakers pop when I shift into gear the the filter no longer works. The speakers pop when I disconnect the charging cable from my phone and then the head unit exits AUX mode.
I'm afraid there is some electrical issue going on causing this. Where should I start looking? Fuses? Which ones would potentially cause something like this?
Update: Checked all audio/power outlet fuses and they all look good. Took apart cig outlet, power outlet, and AUX port to inspect and nothing looks wrong (wires/solder points). I also disconnected each power outlet at a time to see if one or the other was causing it. No change. I also disconnected my footwell LEDs that are tied into the cig outlet and still no change.
I ordered the TSIB parts and hope this fixes the issue some how. I'm just nervous that it'll blow the filter like the Amazon filters I've bought before and waste all that money.
Old 05-17-18, 06:17 PM
  #126
Toxicxk23
Toxicxk23's Avatar
Update: Received the TSIB aux port parts. Installed it and same ****. Another thing I did notice is that when I turn the volume all the way up with no music playing, I can hear a 1Hz static popping that matched the 1Hz blinking of the : in the clock. Leads me to believe that the issue lies in the head unit somewhere... *sigh* I WILL figure this out!!!!
Anyone have diagrams or pictures of the boards in the head unit?
Old 12-09-18, 11:27 PM
  #127
Viru
Viru's Avatar
Forgive me if I overlooked this in the thread somewhere, but does anyone have the part number for the Lexus noise filter? I'm having this issue and would prefer for the fix to be more hidden than an external Ground Loop Isolator.
SpeedRcr
RC - 1st Gen (2015-present)
05-16-18 10:08 PM
Tarkio
ES - 5th Gen (2007-2012)
10-28-08 08:23 PM
2thfixr
10-18-08 08:43 PM
ben_r_
13
08-25-07 08:17 AM
Quick Reply: Auxiliary Audio Input Port Noise TSIB L-AU001-07 Finally Released!
