CD Changer Issue
Hi All-
Recently Ive had a problem with my CD player. I'll be in the middle of listening to a CD and suddenly it will stop playing. I can try to eject the CD but that doesn't work. I can try to change over to another CD but then that doesnt work either (think blinking disc for a while on the audio screen.) So basically when the CD player stops working, im left without a working CD player for about a day or two, and then the thing will decide to work again.
I took my car in to the dealer today to have them look at it, and they said that it states "somewhere in the manual" not to use burned CDs in the player, eventhough there is the "MP3/Wav" thing underneath the CD opening. They told me to use regular CDs in my player for a week and see if any got stuck; and if some did, then they'd order me a new unit.
I think its pretty lame that by now lexus doesnt make their cars able to play burned CDs. My 2000 honda civic is worth a fraction of what my Is250 is worth and it is able to play burned Cds...
But yeah, anyone else with this problem?
Oh yeah btw I have a 2007 Is250 w/o ML
Cycle Savant
Actually, my CD/DVD player started acting up, and would intermittently not eject any of my discs (none of which were burnt; all were original store-bought discs). I can load a disc, but it sometimes won't eject it.
My dealer is changing my CD/DVD player next week for me under warranty.
Well I use nothing but burned MP3 cds in my cd changer and I have never gotten one stuck, so I dont think it has anything to do with the fact that they are burned vs. factory unless you are putting some kind of sticker label on them, then maybe. I have read of a couple other complain about CDs getting stuck and stuff though. How much you wanna bet there'll be a TSIB on the CD changer too at some point!
Mine wouldn't eject, play, or anything else. Dealer replaced it a couple months ago. It took 5 weeks to get my CDs back from the factory. Fill it with non-mp3 CDs you don't like much, and take it back in when it fails, because it probably will. I had both mp3 and non-mp3 in mine. I don't think it's related to mp3 - just faulty players from the factory.
Hi All-
Super Moderator
Thanks for the responses guys-
Yeah i think i will just bs it and tell them that i had problems and was able to get all my cd's out between getting the car to the dealership; they should replace it under warranty, the car isn't even 4 months old!
And thank you for confirming my suspicions about the playability of burned cds; i figured the Is should be able to do that...
At least for the ES350 the manual is very clear about how you should record CD's for play in the car's cd player. It is equally clear that you can play burned CD in the car's player, else why would they have 4-5 pages of hints and tips on how to burn cd's and what kind of cd's to use. For the ES350 see the Nav Sys Owner's manual, starting on page 223.
BTW a 'burned' CD is stuck in slot one of my player - I've had the car for 3 months. It was playing along fine, but when it went to play the next song...it quit. Hasn't worked since.
I've played approx 10/12 diff burned Cdr's and have not had any problem at all. I use both Maxell and Memorex CDR's so far so good. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I wonder if you could have burned a bad/corrupted file onto a CDR?
The cd player on my 2007 GS 350 failed at 5000 miles and the replacement just failed at 11000 miles. Both times the "stuck" cd was a "book on cd" from the library. The dealer says that some cds are "thicker" than others and foul up the player. This is lame and completely unacceptable for a $50k car.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Mine failed at around 4000miles about 5 months into ownership. Yes I had burned CDs in there and it was just plain stuck... I couldnt do anything. Cant play cant change CDs and cant Eject. Dealer replaced it and came to the house to install the new player. They mentioned that some burned CDs are thicker and might cause the CD player to be stuck but didnt say I cant use it anymore So I continue to use it and now 12K miles later its still working. *knock on wood 350 times *
