Where exactly is the bluetooth microphone?
Sorry if this has been asked before, couldn't find it with search.
While on the bluetooth in the car, I like to know where to direct my voice while talking. The sound quality for the person on the other end is good, but I would just like to know exactly where the mic is, because I can't seem to locate it.
Also, I've found that you gotta turn off the A/C or lower it to get rid of that wind tunnel effect.
Hold down the INFO Button if you have NAV... and turn your headlight signal from the off position to the the middle position (the position before you turn your headlights on) back to off and keep doing that until your nav screen shows an alternate menu with one of the options being bluetooth...
You can look through that and you can adjust the sensitivity.
Super Moderator
The mic sensitivity is a "service mode" setting, it was intended for use by a service technician, not the owner.
When I picked up my car the dealer told me to point the a/c vents down cause the mic is really sensitive, ever since I do that it works better. Some people say they can't hear me then I point the A/C vents down and they say it's better. I didn't know you could adjust sensitivity yourself, thanks for the info.
DrummerK
01-14-07 12:07 PM
2006, 2007, 250, 450h, adjustment, bluetooth, gs, headlights, is250, lexus, mic, microphone, noise, rx400h, turn
