IS Paddle Shifters Compared to Others
I'm still confused.
Yes, I understand the shifting is not nearly as quick as a manual, but if you put the paddles at the gear you want to be, the only time the shifter deviates from your choice is when the gear you want for a certain speed is too high the car....
So basically the paddles don't allow you to drive 20mph in 6th gear...
Is that the basic complaint people have about the shifting logic of the car? (And the fact it doesn't go to 1 at a stop).
I can't think of another automanual transmission that doesn't have this sort of logic in place...
The paddles in the BMW 335i actually work just like a manual. The BMW has a "full throttle resistance point" on the accelerator. So basically, in manual mode, you can lug the engine down to 1,000rpm's in any gear, give it full throttle and it won't downshift. It will, however, upshift at redline. But anywhere in between you have full control. For example, at full throttle at 3,000 rpm in 4th, if you upshift to 5th, it will respond and shift up to 5th instantly. Just like driving a manual. The Lexus system is really quite lame in comparison. With Lexus it won't upshift when you want it to. And it will down shift on its own.
Super Moderator
That's how it works with the Audi, but not with the Lexus. The paddle shifters only allow you to choose the maximum gear that the transmission can automatically choose, not the actual gear. This is particularly noticeable in freezing weather. The car won't shift into 6th gear even at 65 MPH until the car warms up. (The green display says "6", but if you display the gear indicator by pushing the DISP switch on the wheel, you'll see it is still in 5th)
I'm still confused.
So the people that are upset about the car not being in 4 when you want it to be 4, are the people who want to drive at a lower RPM than normal, which isn't sporty shifting....
I guess I'm just not understanding what exactly people want out of the device... what do you want it to do besides respond faster. (except for the automatic downshift to 1. that would be better).
05-06-17 12:30 AM
