DIY Sport Pedals IS350 IS250 w/ Pictures!
Old 04-21-17, 10:16 AM
  #151
mandyfig
mandyfig's Avatar
Got my set. Thanks for this DIY. I will be studying this very carefully. I did by SC and that required drilling holes and that was not easy, you needed a angled drill due to lack of space. I ended up borrowing from my co-worker.
I can not wait!
Old 04-21-17, 11:29 AM
  #152
mandyfig
mandyfig's Avatar
My set is coming from Sewell. As well as the others who have purchased from the same vendor...
I miss Sewell...
Old 04-21-17, 12:39 PM
  #153
5nX37
5nX37's Avatar
I can not wait!
This install won't be as difficult for you then. Just getting the accelerator pedal assembly is gonna be quite a task. Also best to try and not drop that 10mm nut into the carpet insulation. There's a wide gap right under that top nut area where it can easily fall into. I would suggest blocking the gap with painter's tape or something coupled with a magnet bolt picker tool just for extra measure. GL.
Old 04-21-17, 12:42 PM
  #154
mandyfig
mandyfig's Avatar
Thanks for the tip on the gap. What size of nut is it, 10mm? I can not wait to get my set.
Old 04-21-17, 12:43 PM
  #155
mandyfig
mandyfig's Avatar
And I have the swivel adapter as well. Time to put it to good use!
Old 04-23-17, 12:02 PM
  #156
mandyfig
mandyfig's Avatar
The set is coming in on TUE, can not wait to get them installed!
Old 04-24-17, 11:18 AM
  #157
mandyfig
mandyfig's Avatar
My F Sport pedals will be delivered tomorrow, and they will be installed by COB!
Old 04-25-17, 07:09 PM
  #158
mandyfig
mandyfig's Avatar
It came in!
Old 04-25-17, 07:10 PM
  #159
mandyfig
mandyfig's Avatar
Partially installed, it was late in the day..
Old 04-25-17, 07:11 PM
  #160
mandyfig
mandyfig's Avatar
I like it a lot! I have the set on my SC as well. Thanks for the inspiration. I must remember to put tape on the hole so as not to lose the nut.
Old 04-25-17, 07:23 PM
  #161
mandyfig
mandyfig's Avatar
The clips stayed on the footrest, which was fine. I took the clips off the new foot rest an shoved it right there...done.
Tomorrow I will tackle the gas pedal install.
Thanks for the many tips on this thread.
I can not wait.
Old 04-26-17, 12:56 AM
  #162
suprawhite
suprawhite's Avatar
Nice!!! I see you have the genuine All Weather Floor Mats. I got mine at the same time I got those pedals also.
Old 04-26-17, 03:52 AM
  #163
mandyfig
mandyfig's Avatar
Thanks, I like the all weather , easy to clean. I miss Sewell.
Old 04-27-17, 04:10 AM
  #164
mandyfig
mandyfig's Avatar
Well I thought I had a set of the universal flexible socket adapter, could not find it last night! I tried the normal one, that is a beatch to get into, let alone turn. I quit, I need to get a set of the flexible adapters!
Tip, put double sided tape on the socket so you not lose the bolt...!
Old 04-28-17, 04:46 AM
  #165
mandyfig
mandyfig's Avatar
A friend let me borrow a 3/8 Universal Flexible Adapter. FAIL, I could not get it to work.
Dropping by the store to get a ¼ set! I am pretty sure I will knock it out.
I do have a bruised rib trying to get it done last night, it does not help if you are a bit tipsy!
Quick Reply: DIY Sport Pedals IS350 IS250 w/ Pictures!
