DIY Sport Pedals IS350 IS250 w/ Pictures!
#106
just installed the sport pedals today, took like 15 mins, actually the hardest part for me was installing the new brake cover,..taking the gas pedal out was easy of course with the angle adapter, and i used a nail that fit the hole of the pin you have to knock out, that was easy, and puting the top right nut back was easy also, i put the nut inside the socket, then taped it just on the outside to hold the nut so it doesnt fall, then when you screw in the nut a little, just peel the tape off,
#110
#111
#113
#114
does anyone know if our cars share the same pedals as the is300?
on ebay there are several sellers who have "oem alluminum pedals" for the is300, they look EXACTLY like ours. I also went on sewell to find the alluminum set for the is300 and came up with nothing, only for our cars, could it be that they are the same?
#115
I did use a clamp I used a happen and a super tiny screw driver and went havoc on the screw took a minute and super slowely it starts to come out. Remember it gribs on the plastic when taking the pin out..so dont be afraid to use some force
I but it between my legs and went at it for 20minutes till it was loose
#116
Jeff
#117
Hi there,
The installation instruction link doesn't work anymore.
http://www.sewellpartsonline.com/imp.../IS_pedals.pdf
If anybody saved a copy, could you please share it with me?
Thanks,
Kevin
Thanks,
Kevin
#118
I got the aluminum pedal set from the Black Friday Sewell sale last weekend and was surprised when i got the set this week. I had thought the gas pedal was just the pad and not the entire pedal that this mod was before ?? It should be easier then one would think but i haven't had a chance to do the install yet ??? Has anyone installed their pedals from last week's sale ??? TIA
#120
haha yea I just installed mine too, PITA, thank god JR (mymrmis350) has a crap load of tools cuz we ended up taking off the whole gas pedal assembly.
NO WAY anyone would ever be able to push the pin out while the pedal is still on. Once out and WITH a hammer it still took about 10 mins.
