DIY Sport Pedals IS350 IS250 w/ Pictures!
#121
Hi there,
The installation instruction link doesn't work anymore.
http://www.sewellpartsonline.com/imp.../IS_pedals.pdf
If anybody saved a copy, could you please share it with me?
Thanks,
Kevin
Thanks,
Kevin
5gears-IS (04-21-17)
#124
What a PAIN IN THE ****!
Foot Rest - Pulled right off, snapped in the new one.
Brake - Ripped the old one off, slipped the new one on (slide the top on first and then pulled it down on the bottom... used a flat head to pull the sides out)..
Gas - WTF.. Unbolted easily, but a freakin PAIN to get the little silver locking piece out. I beat that thing then finally just ripped the old pedal off and used a hammer to beat the silver locking piece out. Once 20 minutes was wasted getting the locking piece out, it only took me 3 minutes to reassemble and install... Am I happy I did it?
YEEEEES!
YEEEEES!
#130
This turned out to be a PITA project for me. The easiest part was getting the pin out...
Foot rest - when I pulled it out, the white clips pulled off the foot rest and remained on the pins. I should have just pulled the white clips off the new one, but I tried to pull the bottom one off the pin in the car and it broke. I ended up taking a small chisel to break it off. I left the top on on. Would have been a piece of cake had I just reused the white clips....
Break pedal - This little bugger wasn't too bad. I used a really small flat head screw driver to pop the rubber around the break pedal. Took about 5-7 minutes to get it installed.
Gas pedal - If you have big hands, I really feel sorry for you! Bottom nut was easy peasy to get off. Top nut was a bit more difficult, but not too bad since I had a knuckle socket (or whatever you call it). Came off pretty easy, but was hard getting my hands up there so the nut wouldn't fall behind the carpet when taking it completely off. I didn't have a vice, but did have a pin removal punch. Pin came out pretty easy - just took a minute. Putting the new pin in took lots of banging! However, once it got started and was about 1/4 of the way in, it started to go a bit smoother. It really was a pain to get the top nut started due to the really small space to work with. However, once it was started, no problems.
Overall, I guess it wasn't too much of a pain. ....but when you look at the parts, you'd think the job would be a piece of cake.
I'm really happy with the upgrade and think they look about a million times better than the stock pedals. Thank you Sewell for the black Friday special! :-)
#131
I guess tools is everything for the job.
It only was easy for me because I had the tools.
For the gas pedal, I could not imagine doing it with the angle adapter and extension. Also, having a bench vise and the right size punch is essential. I started to use the first punch (taper) I could find and it wasn't going to work....started to expand the pin. Luckily, I noticed this, so I looked for the correct straight punch. It pushed through easy and the new one went in easily. Again having the vise helped, because everything remained rigid.
The brake pedal was easy, just used a small flat blade screwdriver to work it around.
When I popped off the foot rest, the white plastic clips stayed on the rods in the car. I used long needle nose pliers to grab them and pulled them out. Without the pliers, I am not sure how I would have gotten them off.
#132
someone PLEASE help me I've already spent 3 hours no luck trying to get the stupid pedal assembly out.... even with the angle adaptor I have no luck... how is it even possible i put my finger back there and their is no room
#134
Huge thanks to euroimage for putting it together.
DIY: sport ebrake pedal
https://www.clublexus.com/forums/is-...ake-pedal.html
#135
I just did my today its very easy if you know the trick. To remove the pedal out first unbolt the bottom nut then start losen the top one but make sure u dont unbolt it all the way out just half way so you can at least lift the bottom out and move it to the left and that you will have more space to put your hand in and unbolt the top corner one. I found it alot easier if you use 2 inch C clamp to reinstall the pin its much much easier. And put it back same way as u took it off insert the top corner first but leave the bottom hang to the left so you can put the nut in and after you screw in alittle in then insert the bottom
