Ordering the ML package after?
Hi, i live in Canada and the ML option is not available here.i have the navi package however in my 07 is250 awd. is there possible chance to order the ml player only from the states? or using the nav tv a better option?
Yea thats not really an option that can/should be ordered separately. Its too many parts and youd have to ripe apart damn near the entire car to make the swap.
1 Post
If you need more power in your audio system, I would suggest a professionally installed aftermarket system, but you already have the navigation system.
Super Moderator
The player is only one component of the ML system. The amplifier in the trunk, the speakers and the wiring harnesses are also different.
1 Post
the ML option is a factory install option, u can't add it on later. You need a different wiring harness. The sub is different, the speakers are different. I say u spend that money on adding on an aftermarket system.
