Look what Happened to my Tires!!!
So the car has 10,000 miles on it. And like I mentioned in a previous post, i took it in for TSIB reasons. While they were changing the brakes, this is what they found with BOTH my front tires
the rears are fine. look like normal even wear. the fronts however looked like ***. the car does have the eibach lowring springs on it. but does the camber that the car has now after the lowering really effect the tires wear this much. i mean the tires are in great condition minus the outside wear. way toooooo early in this tires life to be replaced. what are the rest of you doing to compensate for your lowering kits effect on your tires camber. until they come out with a kit i am stuck replacing tires often i guess. is there a camber kit out for the ISx50 yet that will work.
how long have you had the car lowered? When i had my car aligned after lowering it with the Tein CS coilovers, my camber was still within the factory specs, the only thing that was out was my SAI. I was told the SAI is not correctable but does not really affect anything and would not affect tire wear.
To me that looks like very premature wear but cant say for sure...
Mine is NOT lowered, and I had similar wear on the inside of my right front Dunlop at 12000 miles. I doubt it has a lot to do with lowering. I had the tow-out changed to toe-in, and have about 1000 miles on the new tires. I replaced all 4 with Michelin all seasons.
Tech Info Resource
