Who all though the top speed limiter was set to 142 MPH?
Tech Info Resource
So, the '08 New Car Features is out on TIS, and I figure since there's nothing on the IS-F yet, I'll take a gander and see what they really changed from 06/07 to '08. Lo and behold, I'm checking out the Appendix where all the real tech info hides (just wanted to see if they'd upgraded to a 2.93 GHz Core 2 Extreme QX6800 with DDR3 and a 1333 FSB for the '08 ECM - sorry no dice there!) and what do I see? New top speed numbers! Guess what? They're NOT all the same!?!?!
The IS250 MT is limited to 144, the IS250 AT is limited to 140, the IS350 is limited to 144, and finally - the AWD 250 is limited to 131 mph.
So, thinking I'd found a real change, I went back to the '06 NCF Appendix to see what the original numbers were (didn't ALL the magazines report it to be 142???) and sure enough - THEY'VE ALWAYS BEEN THOSE NUMBERS! Those lamers at the magazines believed the marketing pukes again and published the WRONG numbers!!! Imagine that!!!
Not only that, but the redesigned seat for more rear leg room (true) does not show up as changed in the master spec sheet. Still 777mm.
Other confirmed changes - Wheel colors are changed for both 17 and 18 inch wheels, and unlike years past, they are now different.
- Scuff plates are indeed white, not blue.
- TPMS time to warn about missing input from pressure sensor dropped from 51 minutes to 20 minutes (aftermarket non-TPMS compatible wheels will be even MORE annoying if you don't take countermeasures.)
- French has been added as an optional language for the multi-display (however, there STILL does not appear to be a way to change the display from degrees F to degrees C!)
- They've added a buzzer feature to warn when the key battery is low.
- And finally, the one we've all been waiting for with baited breath - the theft deterrent system now cancels when ACC or IGN function is selected, not just IGN.
Sorry - no factory N2O or 275/35/18 and 355/35/18 tire options, no factory headers or Recaro seats, no TRD LSD, none of the really good stuff this year - but we can still dream about next year!
Thanks, that's some good, detailed info.
Blue or white scuff plates, don't think it makes much difference. The blue is nice and soft and goes well with the rest of the ambient interior lighting. White will probably stand out a little more, depending on how bright it is. I wonder what prompted Lexus to change such a small item mid-cycle. It's not exactly earth shattering.
Javier
^I should have taken pictures. There are two leg cutouts on each side of the back of the front seats. It doesn't look like much of a difference, but when you sit in the back seat, my legs actually fit without having to contort them sideways.
Javier
Javier
Nice thread hijack guys.
Back OT. I wonder if the speed limiter is set to actual speed or as indicated ? If our speedos are truly 5% conservative, than an indicated speed of 144 would be an actual speed of apprx 137. Then again, to achieve an actual speed of 144, you would need apprx 151 as indicated. Anyone care to test this . . .
However, the big question is: does it compromise front passenger comfort and seat cushioning?
How is this a thread jack? This was mentioned in the original post:
Anyway...
Those IS-F seats are awesome. There's more lateral support in both the front and rear seats, and boy are the comfy - they just seem to hug you.
Javier
Javier
These two interest me the most...
1.) So it will be the "Liquid Graphite Finish" similiar to the 2001 IS300 Graphite Polished finish ??
(already found on the G-Spider & ISP-Mode Wheels)
The Split 5 Spoke design remains the same.. (I assume)
2.) I guess the Sport Pkg will include the new embossed "Aluminum Scuff plates"?? (still not illuminated)
Here is a pic of the proposed new 18" wheel finish & I would guess the now embossed Aluminum Scuff plates for the Sport Pkg
Joe Z
P.S. - Maybe a thread title change is needed for this one.........
