tpms contraption
tpms contraption UPdate
this is what i made it turns if off but, it leak from i dont know where.
i think its leaking from the valve stem. does lexus use a special valve stem? cause when they installed my work vs-xx, i guess they transfered the valve so i dont know what to do. i didnt mount the tpms. i put newpaper inside to stop the rattle, may that be the problem. it senses pressure, but after 5min it read low tire again !! help! i only used 1 endcap and the other end can be open. i presure test it with water and there were no bubble. im think its the valve stem?? its sitting at an lil angle. any one out there can solve this problem?
