Engine Oil level
The other day I posted a thread on how to check my engine oil level, and I just got a chance to do it today... currently have 3k mileage for 7 months and my oil level is still max. Is this normal?
I hope you had your oil changed at 6 months. Either way, it seems ok, as long as its not higher then the max on the dip stick. Vice versa, if its lower then the min then you should be worried.
Tech Info Resource
You're fine. Nothing to worry about at all.
