Engine sound depends on oil?
For those who have used different oil grades, do you know if the oils have any effect of how the engine sounds?
Every since i switched to 0w-40 Mobil 1, i notice when eccelerating the engine growls somewhat especially in the morning, after i have warmed up the car even.
Super Moderator
In my RX300, which is an noisier engine than the IS of either generation, the M1 0W40 was just as nosy as the 5W30, however, the quietest oil I have used is the green version of the German Castrol 0W30, which I am using now.
I would be surprised if the 250 differs to 350 in what is recommended in the manual.
Lexmex, how is it possible for 0w grades to differ at start up temp? I found the engine growls during initial running just after warm up (not 100% at running temp. yet). Could the thinness of the oil be why the engine makes more sound? if so could mean insufficient lubrications of internal parts.
Koz
You don't have to live in a cold climate to benefit from using 0w-20. The most engine wear damage (up to 80%) comes from the time the oil takes to get to the vitals, during start-up. The better the flow rate, the less time it takes for the oil to reach the vitals. If you look at the temp range of 0w-20 compared to 5w-30 you will see that there is a better flow rate at start-up (For the 0w-20) but the protection at operating temp is very close. Also remember, Lexus uses the motor oil to activate the VVTi systems and better cold flow should be an advantage.
Koz
Koz
0w is thinner than 5w and therefore will lubricate less. But there is also the age of the engine, new engines suit thinner oils as the parts aren't worn out and therefore requires less lubrication. Older engines needs more lubrication due to the part being more worned out.
I'm going to switch to Mobil 10w-30 (as there is no Mobil 5w-x in Australia) due to too much growlings.
Super Moderator
However, I know a few people down here who have used some W20s they import andthey have Civics with Turbos and not much noise, but I know a friend with a modified Nissan truck (90s smallsize pickup) and that thing on XW20 makes noise. Thus, the engine has something to do with it also.
BMW7_LS430
Great Deals
09-30-19 08:25 AM
