Help ! No Audio/Sound From my car
When i started my car this morning , there was no sound coming from the Audio
I have '06 350 with Nav and ML
Bringing back to dealer is my last option because i performed the nav hack
each time i start the car i get audio for one second, then i hear a thump and the audio cuts off
the nav functions as normal, i can select AM FM CD , but theres no sound,
Both volume button and volume **** does not work,
No audio from Nav, and theres no beep when i select a menu
I Check the 3 audio fuse, they look fine
any help or suggestions would be appreciated
i have the same issue but only when playing cds or dvds.
post updates, especially if you goto the dealer.
suggestion: suscribe to techinfo and follow the manual to find error codes and isolate the issue based on the error codes. make sure you reset them first then document. good luck!!!
I unplug the battery, hoping it would reset whatever cause it ... No Luck.
I performed the Nav Hack over a year ago. Everything worked fine.
The Audio was working perfectly as of yesterday.
Each time I start the car, i would get audio for 1 second, then a thump ..
In 30 minutes, i'm going to open the car back up ... and un-do the nav hack,
Just spend the last 4 hours putting the car back to the way it was b4 the Nav hack.
Why 4 hours you say???
cuz not only did i do the nav hack, I also did the video input hack , and reverse camera hack...
and have a carputer
https://www.clublexus.com/forums/sho...d.php?t=285374
Have an appointment with the dealership tomorrow... hope it's going to be something small ... like a relay or fuse
and have a carputer
RocketGuy3
10-28-07 09:13 PM
IS3FIDDY
07-06-06 03:39 PM
