wheel spacers? newbie
Don't the stock lugs have to be cut off in order to use those spacers from Project Kics? If so, then I would MUCH rather have the ones from H&R that simply replace the stock lugs with longer ones. Changing out the stock lugs is super easy. The H&R spacers are also about 1/2 the price, and are hub and wheel centric.
I think Javier had the backs done by a mechanic. I can remember the day I tried to install those spacers. Ended up driving five miles on a wobbly wheel because I couldn't get those darn lugs seated correctly. What a freaking nightmare. I learned valuable lesson that day!!!
2IS OG
No, I did install the rears myself. I had to cut the extended rear studs that I bought so they would fit within the hub. The hub can only accomodate studs that are about 2 3/4 inches long. Anything longer and you won't be able to fit the studs into the hub assembly. Once you have them in you can seat them with an open-ended nut. Nothing a little patience and elbow grease can't resolve.
Javier
Javier
808mcv20l
12-15-15 09:49 PM
