Pics of removing boot lid liner
Remove the trunk liner carefully so not to break the clips. Before it comes completely off you have to remove the trunk latch assembly. After that you will remove the bolts for each light assembly on each side. Then you will remove about 8 or so bolts on the inside of the trunk panel. You might have to feel around for them upside down so be careful not to drop any bolts inside the panel. All bolts are 10mm. It's not an easy task until you've done it a few times.
phanotos (03-06-24)
AndyG
03-03-11 08:58 PM
