Other Winter Tire Sizes (IS350)
Old 09-18-07, 06:13 AM
ddehooge
ddehooge's Avatar
Question Other Winter Tire Sizes (IS350)
Well time is creeping up and I'm looking for some insight on the board.
I have a set of 17" x 7.5" rims with a 42+ offset that I am looking to put winter tires on.
I know the recommended winter sizes are as follows:
Original:
225/40/18 Front
255/40/18 Rear
Suggested:
225/45/17 Front
245/45/17 Rear
I have been looking at the following sizes though:
205/50/17 Front -.61% difference in diameter but 0.80 inches narrower (8.07 vs. 8.86)
225/50/17 Rear -.67% difference in diameter but 1.18 inches narrower (8.86 vs. 10.04)
All tires would maintain the V speed rating, this is appealing as the tires are less expensive in this size and it is narrower which I understand is ideal for winter driving.
Am I giving anything up other than some performance due to the narrower tire?
Any thoughts?
Old 09-18-07, 07:42 AM
neova
neova's Avatar
if you want to be able to rotate your winter wheels/ties, go with 225/45R17 all around with an asymetrical tread pattern. I know this will be fine in the front but a bit shorter on the rear but it's a good compromise for the added flexibility to rotating your tires.
Old 09-18-07, 09:22 AM
ddehooge
ddehooge's Avatar
Anyone forsee issues with reducing tire width by an inch in the front and back?
Old 09-18-07, 09:28 AM
ddehooge
ddehooge's Avatar
Well I may have answered my own question here in that the 50 series tires are not rated for a 7.5" rim, so much for that idea.
Old 10-26-15, 09:22 AM
darkarmy
darkarmy's Avatar
I am also looking for a set of Winter Tires + Rims and thought about the suggestion from this form, 225/45/17 all around. Anyone have this setup? any inputs?
TTBomB
12-14-17 05:37 AM
rena
10-20-12 10:03 PM
hung8852
09-19-07 09:36 AM
kaslead
Wheels, Tires & Brakes Forum
11-16-06 08:17 PM
kaslead
10-31-06 08:40 PM
Quick Reply: Other Winter Tire Sizes (IS350)
