Nav Screen Protector
A tip about installation: follow the instructions and have patients - if you exert both it will go on seamless and transparent. I actually ordered 2 for I'm not one to apply patients w/crap like this, but the application took about 5 min and it worked out perfectly.
Does anyone have any suggestions for protecting the navigation screen? I was thinking something along the lines of a clear static cling piece of plastic I could cut and fit over the LCD. One of the problems I could see with this is bubbling, but I'd like to use something that is non-adhesive so that it can be peeled off easily without leaving any residue or damaging the screen. Obviously it would also have to work with a touch screen. Maybe I'm worrying too much, but Lexus says it's delicate and you can't use any cleaners on it and you have to wipe it down with a lens cleaning cloth to clean it.
They call it the "Nav Screen Skin", it fits perfectly with NO bubbles ... just like the I-Pod skin..
See post # 6 in this thread for actual before and after install pics..
https://www.clublexus.com/forums/sho...d.php?t=308099
Best way to clean gently, is with a slightly damp super clean micro fiber.
(Make sure you use one that was never used before & then make it for that use only)
Joe Z
NP - I have one on my RX350 as well It's a very nice product IMO, totally removable w/out adhesive left behind and it's a heavy mil compared to others that I've seen.
the screen protector does not effect one's ability to use the touchscreen -- as I said before -- you can't even tell its there, by look or feel. Just provides a security blanket for your $2XXX+ NAV.
bagwell
03-14-07 08:11 AM
khoaly000
01-30-07 03:01 PM
BottomsUp
09-23-06 04:49 PM
2010, 350, cleaning, convertible, creen, is350, lexus, nav, navigation, neccessary, nevigation, protection, protector, put, remove, screen, screenpatronus
